08-10-2009, 05:03 PM | #1 |
Rock Crawler Join Date: Feb 2008 Location: UK
| What's the output signal from an Rx?
I'm working on a non-RC project that needs an ESC and LiPo pack to run a motor at a fixed speed. Is there a way to simulate the output from a receiver? I've no idea whether the Rx just outputs a variable voltage or some kind of modulated signal. Does anyone know? |
08-10-2009, 07:09 PM | #2 |
Radios produce a variable signal to the receiver. If you want your motor to run at a constant speeds the a ESC (Electronic Speed Control) isn't needed. You might want to find some mechanical speed control and hook it up a some kind of knob. They only have a few contact points to adjust output to the motor. Last edited by constantmotion; 08-10-2009 at 07:12 PM. |
08-10-2009, 08:45 PM | #3 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Here's a selection of motor controllers that work off of an analog input: http://www.robotshop.ca/analog-motor-controllers-2.html Narly1 |
08-11-2009, 12:58 AM | #4 |
Wow, that robot gear's expensive! I managed to find out, like constantmotion said, that Rxs use PWM to control ESCs and servos - not a simple voltage level. I was planning to use a 2s 200mAH lipo to power a pace car for our 65' oval slotcar track. One of the club members thought that it would add a touch of realism to our NASCAR races. Thing is, the pace car needs 6.5v to circulate at a good speed, without crashing. I need a way to get a constant 6.5v at 1A from a 2s LiPo, and the circuit must be small and light enough to fit in a 1/32 slotcar. A small airplane ESC would fit, but I'd need another circuit to generate the PWM signal. Maybe a voltage regulator would be simpler, if I can find a 6.5v circuit. |
08-11-2009, 10:46 AM | #5 |
RCC Addict Join Date: Feb 2008 Location: Crawlerado
Try a Castle BEC. They are good to 7 amps and 25 volts and you can set the voltage to whatever you need. It'd be nice and small too |
08-11-2009, 11:07 AM | #6 |
I have thought of using a BEC, or maybe one the regulators that are starting to appear for the nitro and plane boys. They allow the Rx to be run from a 2s lipo. I've actually had a CC BEC on order for a few weeks now. There's no stock in the UK, as Castle are changing to a new UK distributor. The BEC is seen as a low priority item, so none have been imported for a while now. Does anybody else make a decent, adjustable, BEC? I need one for my crawler. Alternatively, are there any US sellers that will post a CC BEC and castle link to the UK without charging silly prices for shipping? One place that's recommended here wants $20 shipping, but the USPS only charges about $6. |
08-11-2009, 12:53 PM | #7 |
You can get it slow shipped for just a few bucks, yep. Flat rate priority is $18 and EMS is almost $30 now. I could slow ship it if your UK supplier won't have stock for a while. I was going to suggest the BEC as your best bet. Otherwise you need a PWM circuit and speed controller, and you don't need all that. |
08-11-2009, 04:43 PM | #8 | |
Thanks for the offer. I tried to PM you, but couldn't. I'd like to order a CC BEC and Castlelink, shipped by normal USPS. Could you ship them separately (2 parcels)? If the goods plus shipping goes over £18 ($29), we have to pay import tax plus an £8 ($13) handling charge. 2 separate parcels avoids this. | |
08-11-2009, 05:16 PM | #9 |
send me an email or just go to my site and place the order.
