08-15-2009, 03:02 PM | #1 |
Rock Stacker Join Date: May 2008 Location: bremerton
| mamba monster no worky worky help please
well before i posted i used that informase search button i found a lot of similar problems but nothing like mine ,this is new mamba monster 2200kv first run it worked beautifully then i turned it off changed the battery , the only thing was there was a slight spark from the deans plug when i was starting too hook the battery up, i pulled the battery away every thing looked fine so i hooked the battery up no spark this time , now the steering works , the fan comes on, & the green led is blinking oh and it beeps twice when you turn it on that's it. any help would be greatly appreciated curtis |
08-15-2009, 03:55 PM | #2 |
Quarry Creeper Join Date: Dec 2008 Location: other side of the track,the bad side
are you running a 4s???if so thats deans is not enough connection. First I would run 6mm bullets. my friend just had this happen. He sent it to castle and the 1 of the caps were blown. I was starved for power. just my .02 cents. this is why I love nitro |
08-15-2009, 04:08 PM | #3 |
Quarry Creeper Join Date: Jun 2009 Location: Abbotsford BC Canada
Are your batteries the same amount of cells?.Your description isnt very clear but my first thought is that You need to calibrate your remote to the Speed control..Read your mamba manual,its all in there Last edited by xv-townboy; 08-15-2009 at 04:11 PM. |
08-15-2009, 04:13 PM | #4 | |
thanks for the fast response curtis | |
08-15-2009, 04:19 PM | #5 |
08-15-2009, 04:23 PM | #6 |
Have you set it up for that type of batt?.If its still on a lipo setting then the cut off wont allow that battery to work possibly..I use the bullets and deans on a 5,s set up with that same esc,the sparking isnt all that unusual for the Monster.Mine sparks all the time.
08-15-2009, 04:34 PM | #7 | |
thank sooo very much for all the help , you are a life saver curtis | |
