| | #1 |
| Pebble Pounder Join Date: Jun 2009 Location: Jackson
| I have two different saddle packs that use the Elite 1500 NiMH 1500 mAh cells. One pack is 6 cells and the other is 7. For charging purposes, what is the actual capacity of each that I chould put in my charger settings? Thanks |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Mar 2009 Location: Victoria BC
| generall you want to charge at 1amp per 1000mah rating, so both you would want to charge at 1.5 amps, but 1 or 2 amps (what most "cheaper" chargers have for settings will do just fine. but it sort of sounds like your charger you can set the where it peaks... so i would set it at 1500mah, just like the batteries are rated at |
| | #3 |
| I'm Dracula, Bitch. ![]() Join Date: Sep 2005 Location: Houston, TX
| Some folks will charge them at higher currents, but I like to stick with 1C for mine. For example....if I have a 1500mAh pack, then I charge at 1500mA. The number of cells will not matter when selecting a current at which to charge....it simple increases the output voltage. |
| | #4 |
| Picky Fab'r/Acetal Junky ![]() Join Date: Jul 2006 Location: Arizona Desert/AJ
| The "capacity" of both packs is the same...1500mah. The voltage is the only difference (7.2v vs. 8.4v) |
| | #5 |
| I wanna be Dave Join Date: Sep 2008 Location: four o six
| | #6 |
| OK. I guess that makes sense. I can change my charger sittings in .1 amp increments, so whatever I want. I understand the 1c guide. Do you guys feel that is an across the board thing, or do you sort of have a limit? In other words, I also have a couple of 5000 mAh packs and have not been charging them at the full 1c - 5 amps. Just thinking that might be a little much for some reason. I have been using 3 amps. |
| | #7 | |
| | #8 |
| So, if I wanted to convert a 6 cell to a 7 cell pack, I can't really mix and match. Adding one of the cells from a 1500 pack would not work with the 5000. |
| | #9 |
| Rock Crawler Join Date: Feb 2008 Location: UK
| | #10 |
| | #11 |
| | #12 |
| Yep. How many cells can a Sidewinder take? I know 7 is the limit for the Rooster on my son's rig, but can the Sidewinder take 8? I can't really do anything with the 5000's, but I have a total of 19 1500cells so I could get two 8packs out of them. |
| | #13 |
| Everybody Loves Hypnotoad ![]() Join Date: Jan 2006 Location: Phoenix
| Yes you can get 2 8 cell packs from 19 cells, with 3 left over, 2x8= 16 cells hope that helps you can go 3 cell lipo with a 4600 kv brushless with a sidewinder, I have run a 8 cell nimh with no problems. Last edited by Ghost; 08-17-2009 at 07:06 PM. |
| | #14 |
| I think the max on a sidewinder is 12 cell nimh or 2S lipo.... |
| | #15 |
| Rock Crawler Join Date: Oct 2008 Location: Florida
| The sidewinder can handle a 3s. It has the same capabilities as the mamba minus the direct usb connection. 4600: Up to 3s LiPo 5-12 cell NiMH** 5700: Up to 2s LiPo 5-8 cell NiMH |
| | #16 |
| thanks for the correction...the reason I could remember it went up to a 2S was I was looking at the 5700kV... stand corrected. |
| | #17 |
| My mind is in crawler mode as for the two being comparable |
| | #18 |
| Well, I am not running the sidewinder brushless, so I probably will max out at 8 cells. |
| | #19 |
| Rock Crawler Join Date: Dec 2007 Location: GILBERT
| Thread Tools | |
| Display Modes | |
