Thread: Mini servo question.
Old 08-17-2009, 08:13 PM   #1
Default Mini servo question.
A thread in the MRC section was recently started asking about better than stock mini servo's for the MRC.
As is most offen used, I reccommended the Hitec 645 standard size (and yes, I know it isnt a mini)
But the OP was strongly against using a standard.
I recomended a the ultra mini (metal gear) from hitec and a futaba...
But what I wanted to know is,
could two smaller micro, or sub micro servos be wired in parallel to the esc to achieve the same result. I know it would be more current draw than one servo alone, but would it be too much.
and any ideas on which mini, micro, or sub micro would be best...?
thanks guys
soundcolor is offline   Reply With Quote
Old 08-18-2009, 02:14 AM   #2
Who's your Daddy-0!
TattooKenny's Avatar
It could work but would not be comp legal at all. Stick with 1 servo
TattooKenny is offline   Reply With Quote
Old 08-18-2009, 12:43 PM   #3
Rockfrog's Avatar
http://www3.towerhobbies.com/cgi-bin...?&I=LXLN95&P=7
I've had good luck with this one, cheap and worked well for my 1/18th VMG based crawler with 2.2's, it's still going strong after 5yrs of bashing.
Rockfrog is online now   Reply With Quote
