Thread: need more wheel speed.
Old 08-19-2009, 04:06 AM   #1
Default need more wheel speed.
I have a novack 55 turn motor and Iam lacking wheel speed. Iwas thinking of a 35 turn integy lathe motor. But Ithink it won't have enough torque because my comp rig is pretty heavy. And im also running a regulare stick pack 1800 7.2v. Or will i better of with a 45t motor.
Thanks.
Tklan Crawler is offline   Reply With Quote
Old 08-19-2009, 04:39 AM   #2
Sucking Hind Teet.
Frankenwheely's Avatar
Thanks.
I'm guessing you're using a 6 cell? I run a 1500 split 8 cell pack with a 55t motor and it's got some wheel speed. But I'm sure everyone else will say go lipo. Which is the true wheel speed answer.
But if you want cheap and works great try 1500 battery with the split 8 cell.
You can also try a smaller spur gear.
www.cheapbatterypacks.com
Frankenwheely is online now   Reply With Quote
Old 08-19-2009, 11:28 AM   #3
I'll be frist; 3s Lipo!!!!!
Oh I see ya got a novack 55t which means ya possibly got a rooter that won't handle 3s; sucks for you :-(
oldhippie is offline   Reply With Quote
Old 08-19-2009, 02:32 PM   #4
Cool
I second that!! It is more money for a lipo. The spur gear is also a good idea!
h2oboy21 is offline   Reply With Quote
Old 08-19-2009, 02:42 PM   #5
Manning's Avatar
I run a 8 cell Ni battery (9.6v) with a 35 turn motor, and feel it's about right. Wouldn't want anything slower.
I'd get a 35 or maybe even a 30 turn motor if you are stuck with a Rooster and can't go above 7 cells/8.4v.
If you have an esc that will handle 3 cell lipo, that is a very good option. It'll be gobs (fancy technical term) faster.
Manning is online now   Reply With Quote
Old 08-19-2009, 04:50 PM   #6
x3! Lipo!
CHRIZAD is offline   Reply With Quote
Old 08-19-2009, 10:04 PM   #7
samaruki's Avatar
get one of these: http://www.allerc.com/product_info.p...oducts_id=4650 they have lesser powerful ones it that is too much punch....
samaruki is offline   Reply With Quote
Old 08-20-2009, 01:24 AM   #8
I have stock wheely king esc do you think it will handle a 8 cell pack.
Old 08-20-2009, 01:41 AM   #9
I have run 9 cell on rooster crawler with dual 55's with zero problems. It got warm, that was it. A lot of people have run 8 cell with no problems. The one thing that bugged me about the rooster was the glitch using a tq3 radio. Sold it because of that.
Ripperfi is offline   Reply With Quote
Old 08-20-2009, 08:15 AM   #10
The 35 integy will still have plenty of torque and IMO plenty of nice wheel speed with your battery. Just as an example my friend runs a 35 integy with a 1600 nimh saddle and has enough wheel speed to hop a gap and it has no loss of torque in fact the slipper (which is fairly tight) gives in before the motor gives up I will say this I run the same setup as far as motor and gears but on 11.1 lipo and it is twice as fast! So to make a long story longer go with the 35 not the 45, you will ge plessently surprised at the wheelspeed improvement and it wont break the bank.
goodoldlevi is offline   Reply With Quote
Old 08-20-2009, 01:42 PM   #11
ive been waiting to go from my Novak 45t to any 35 t ican get my grubby hands on for like a month.
i run 7 cell NIMH, and want the gap jumping , and the disco spin rollover ability
BEELZEBOB is online now   Reply With Quote
Old 08-20-2009, 06:24 PM   #12
no way, i run lipo batts that are $30.00 for two. i was paying $25 for one split pack.
jamesdicken is offline   Reply With Quote
Old 08-21-2009, 01:58 PM   #13
Lipo packs and nimh prices? not much of a difference but youre getting what you want.
Old 08-21-2009, 02:33 PM   #14
the HPI Jolt ESC (on the WK) is rated at 7.2v, but some people have reported using 7cells (8.4v) with it without problems.
Get a single 2/3a cell, wire, and a set of male/femail deans and try adding a 7th cell.
It will give you more wheelspeed and torque.
From there, do not go nuts with larger pinions, then the Jolt will get hot.
sweli is offline   Reply With Quote
