| | #1 |
| Quarry Creeper Join Date: Apr 2009 Location: columbus
| I have a clod crawler with dual steering. I am running a Tekin rebel 2 ,11.1 volt lipo and two towerpro 995 servo's trying to push 40 series tires. Do I need to run ONE Castle creation Bec or two ? If it's one how many volts should I set the output for ? If it's two I still need to know the output voltage because I need to run one until I can get the second one. Thanks.Bob |
| Sponsored Links | |
| | #2 |
| Quarry Creeper Join Date: Oct 2005 Location: SoCal
| One bec should be fine, and 6.0 volts is standard for most servo's. |
| | #3 |
| PapaGriz Yo ![]() Join Date: Apr 2004 Location: Planning
| I don't know how much power the 995 draws. I have two Hitec 5955 servos on my super and I had to go to 2 BECs. Both of them are set at 6.0 volts. Try it with one, worst case is it'll glitch and you know you need two. It might work fine with one. |
| | #4 |
| Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
| It will ! |
| Thread Tools | |
| Display Modes | |
