| | #1 |
| Quarry Creeper Join Date: Apr 2009 Location: columbus
| What voltage should I set my CC BEC at ? I am using 2 towerpro 995's and a 11.1 volt lipo ? I am wiring it to bypass the RX only using the signal wire from the RX. That way i'm not overloading the RX. Thanks. Bob. |
| Sponsored Links | |
| | #2 |
| I wanna be Dave ![]() Join Date: Jan 2005 Location: Hueytown, Alabama
| I would set it at 6v. |
| | #3 |
| Hateraide ![]() Join Date: Dec 2008 Location: Mission BC
| Size: 40.7mm X 19.7mm X 42.9mm Weight: 55.0g Operating Speed: 0.2sec/60 degrees (4.8V); 0.13sec / 60 degrees (6.0V) Stall torque: 10.0kg/cm (180oz/in); 15kg/cm) (208oz/in.) Temperature Range: 0 - 55 degrees Dead band width: 10us Operating Voltage: 4.8V - 7.2V they can handle up to 7.2V but i would go over 6-6.5 that way they will last longer without frying them |
| | #4 |
| | #5 |
| Who's your Daddy-0! ![]() Join Date: Mar 2008 Location: Augusta
| And 6v won't fry your RX |
| | #6 |
| | #7 |
| . ![]() Join Date: Nov 2005 Location: Rock chucking territory
| I NEVER let a external BEC power the receiver, I let the ESC's BEC do that. I found that is best and safest. |
| | #8 |
| Rock Crawler ![]() Join Date: Apr 2008 Location: Calgary
| How do you wire in a BEC then? Just a y harness with the servo with the red wire pulled out at the receiver? |
| | #9 |
| | #10 |
| That drawing is right if you want to do it that way |
| Thread Tools | |
| Display Modes | |
