Thread: Stock Axial ESC
Old 08-20-2009, 11:31 PM   #1
Default Stock Axial ESC
I have a "basher" Axial that I wanted to set up rear stear in, but I am having bad glitching when I try to mix channels. Its doing the same thing with my DX3s and 3PKs and two different RX's, so I know that the TX/RX is not the problem.
So is Stock ESC unable to handle two servos at the same time? or am I doing something wrong? cuz when when I use it as an AUX 3rd channel it doesnt glitch?....would a BEC solve this?
this is just my mess around crawler, so I am not looking to buy better ESC or anything...if all else fails I suppose I can just run it via 3pos 3rd channel.
slimeball is offline   Reply With Quote
Old 08-21-2009, 12:24 AM   #2
Novak Guy
You're probably right, the stock BEC isn't "awesome" by any stretch of the imagination.
If it all works okay with one servo, or the other, or maybe with no load on the 2nd servo, chances are a BEC will help.
Charlie is offline   Reply With Quote
Old 08-21-2009, 07:05 AM   #3
get Tekin FXR...
catkchun is offline   Reply With Quote
