Thread: TQ3 for winch??
Old 08-21-2009, 03:27 PM   #1
Default TQ3 for winch??
Hellow everyone,
I bought a TQ3 a while back and its what I wanted for my build becase I want to run a winch...... It came with a TCS dig switch... Can i use this TCS dig switch for a "winch switch"??? Its a three position switch-Winch in and out?? Just wanted some help...still a noob at this.. Thanks!
Zuk90 is offline   Reply With Quote
Old 08-21-2009, 03:45 PM   #2
benoj's Avatar
it should if its a 3 pos, the only prob i ever had with a 3pos switch on my winch was the center was different on each and i couldnt adjust it
benoj is offline   Reply With Quote
Old 08-21-2009, 04:22 PM   #3
It will work.
srjeeper is offline   Reply With Quote
Old 08-21-2009, 07:04 PM   #4
PapaGriz Yo
Grizzly4x4's Avatar
Originally Posted by Zuk90 View Post
Hellow everyone,
Center position is winch off. There is a white plastic screw adjuster to set the center trim if your winch drifts. You can also wire in a switch to kill power if it drifts too much and you can't adjust it out.
Also read the last section of this:
http://www.rccrawler.com/winch.htm
Grizzly4x4 is offline   Reply With Quote
Old 08-31-2009, 05:41 PM   #5
WOW!!! Thanks for all the help guys!!!
