08-25-2009, 06:17 AM | #1 |
Newbie Join Date: Jun 2009 Location: Rushsylvania
| Saddle packs
I have an AX10 with a 55T Novak motor and stock kit gearing. I was wondering what kind of run times I would get from 6 cell and 8 cell saddle packs?
08-25-2009, 06:36 AM | #2 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
IF you are using 1500mah 2/3A cells NiMH saddle packs, then depending on how heavy you are on the throttle, and how much weight you have added to the truck, you might get 45 minutes +/-. There are a bunch of variables including driving style, weight, gear mesh, terrain, and others that can effect battery life.
08-26-2009, 12:24 PM | #3 |
RCC Addict Join Date: Mar 2009 Location: In a very dark cave can't you tell...
| Saddle Packs
I use a 1500 seven cell pack and I get easy 45 min. Sometimes close to a hour or alittle more. I have a AX10 ARTR with a Novak Rooster Combo motor and speed control. My rig's weight is 5.8 pounds. Hopefully that helps. |
08-26-2009, 06:39 PM | #4 |
Rock Stacker Join Date: Sep 2008 Location: Williamsport
I am getting about 45 minutes with my 8 cell as well.
08-26-2009, 07:23 PM | #5 |
Newbie Join Date: May 2009 Location: San Diego-East County
If your running the Rooster ESC you can only use a 7 cell max pack. Your not supposed to use an 8 cell pack on the Novak Roosters. I run a 6 cell saddle pack from Max Amps and get and average of 30 minutes. Keep in mind that my ax10 is a tank an I do a lot of vertical climbing. Hope this helps.
08-26-2009, 07:26 PM | #6 |
my55t on 8 cells was about 50 mins if i was easy on it and 40 if wide open the whole time, on 6 cells bout 35 if im really hard on it and 40 if easy
08-26-2009, 07:55 PM | #7 |
RCC Addict Join Date: Jul 2008 Location: San Diego
I ran a 10 cell saddle till it died. 50 min run time 55t. Know running a 3 cell Lipo 1300 about 40 min with a 45t. Just so you know.
