08-26-2009, 09:31 AM | #1 |
Pebble Pounder Join Date: Apr 2009 Location: Renton
| To go Digital Servo or Not... That is the question.
OK, last night during our smash/crash fest, we killed the stock AX10 RTC servo in my buddies rig and I got a/some stripped gear(s) in my HS-645MG. Looking for some replacements and having a hard time choosing if I should go digital or not and if it's worth it or not. Another question is, can you run a digital servo on a Tx/Rx that doesn't support them? My buddy is still using the stock Tx/Rx with his RTC, though I know my Jr Tx/Rx will be ok. We're both waiting for the 3PM-MX to arrive, but in the mean time, need to get back up and running. Any suggestions, advice, etc. is welcomed. Thanks! SS |
08-26-2009, 09:34 AM | #2 |
A digital servo should have no troubles with those radio systems. As for which one to get, that's up to you. I just picked up a Futaba S9157 and it seems to work quite well... |
08-26-2009, 09:37 AM | #3 |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
Ditto-- the digial servos will work with the 'old' systems-- I'm running a Futaba S9156 on my Traxxas TQ3-- works GREAT! One of the best things about the digital servo is that it *seems to* center itself in exactly the same place every time. I'm anxious to try one on my street car. |
08-26-2009, 09:40 AM | #4 |
So the extra price on the digital servos are woth it? SS |
08-26-2009, 09:46 AM | #5 |
Most definitely. Also, if you are running a dig, a digital servo works well for that application. I like to be able to hear when my servo is binding....it helps to keep me from killing the servo.
08-26-2009, 10:32 AM | #6 |
Are people getting the digital servo programmer too to setup overload protection? Thinking about ordering the HS-7955TG and perhaps the HPP-21... Thoughts? SS |
08-26-2009, 11:10 AM | #7 |
Rock Crawler Join Date: Feb 2008 Location: UK
I'm using 7955s, and I bought the HPP-21 programmer. I think that it's a good buy. I've fine-tuned the end and centre points, and set overload protection. You can also set the servo to low-resolution mode if your Tx won't give you enough travel. |
08-26-2009, 11:23 AM | #8 | |
SS | |
08-26-2009, 11:27 AM | #9 |
Yeah, if you dont have a good radio that will allow you to adjust your endpoints, that programmer is a good buy....
08-26-2009, 11:28 AM | #10 |
RCC Addict Join Date: Jun 2006 Location: Sin City
| I using Hobbico's C-170 on all my rigs (2.2, 1.9 and super) never had a problem yet and there $30.00 cheaper for pretty much the same thing SPECS: HS-7955TG Tower's Low Price $119.95 Speed: 0.19 sec/60 degrees at 4.8V 0.15 sec/60 degrees at 6.0V Torque: 249.96 oz-in (18 kg-cm) at 4.8V 333.29 oz-in (24.0kg-cm) at 6.0V Length: 1.57" (40mm) Width: 0.78" (20mm) Height: 1.45" (37mm) Weight: 2.29oz (65g) SPECS: C-170 Tower's Low Price $89.99 Speed: at 4.8V = .19 sec @ 6V = .15 sec Torque: 4.8V = 250 oz-in (18 kg/cm) 6V = 333 oz-in (23.97 kg-cm) Length: 1.59" (40.6mm) Width: .79" (20.3mm) Height: 1.5" (38.1mm) Weight: 2.18oz (61.8g) |
08-26-2009, 11:34 AM | #11 | ||
Thanks, SS | ||
08-26-2009, 06:28 PM | #12 |
Yes the gears are titanium. It's just a relabled Hitec HS-7955TG everything is the same but cheaper. So I guess the programer will work.
08-26-2009, 06:39 PM | #13 |
Newbie Join Date: May 2008 Location: Augusta
I keep hearing the CS-170 and TS-170 are relabled Hitecs but I would love to know if anyone has successfully used the Hitec programmer with them. Link to HS-170: http://www3.towerhobbies.com/cgi-bin...&I=LXPHD6&P=ML Last edited by wforicv; 08-26-2009 at 09:54 PM. |
08-26-2009, 07:57 PM | #14 |
I was told it would work with the Hobbico C-170
08-29-2009, 05:18 PM | #15 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Interesting...I have a JR XS3 that I love....was wondering if you need the programmer for this or not....
