08-26-2009, 01:40 PM | #1 |
Rock Stacker Join Date: Mar 2008 Location: Milwaukee, WI
| Associated A.I. super reverse questions
Is anyone using the Associated a.i. super reverse esc? I picked one up and installed it in my AX10. The thing is glitchy. When turning, the throttle won't work. On acceleration, there is a severe lag in the power. Any help would be appreciated. Thanks, |
08-26-2009, 01:55 PM | #2 |
RCC Addict Join Date: Apr 2007 Location: RAMBLIN
what radio and servo are you using. also what motor?
08-26-2009, 01:59 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
08-26-2009, 02:09 PM | #4 |
I believe the internal BEC in the AI's is at 5v 1.2a (2.0a for 30sec MAX)
08-26-2009, 02:16 PM | #5 |
the bec on the ai isnt enough depending on servo. i had the same issue at one point and a ccbec cured it . but all the other info may be helpfull.
08-26-2009, 02:23 PM | #6 |
Sorry about that, I am running: 55T Axial crawling motor or a 15T Fireball bashing motor I have an HPI TX-2 radio and the stock AXIAL RTC receiver and Servo 6 or 7 cell NiMh Battery Forgive my ignorance but I am not an electronics guy, BEC? CCBEC? Thanks |
08-26-2009, 02:34 PM | #7 |
So figured out BEC and CCBEC. However, the stock axial has a 5v BEC as well and it does not have issues. |
08-26-2009, 02:37 PM | #8 |
AX10 came with the AE-1 ESC. It is 5v 1a. Not sure what to tell you. I have an AI Runner Rev, and needed a BEC just to run a Hitec 645 servo. Before that I had the same thing you describe, as it would stop fwd motion as you turned. |
08-26-2009, 02:45 PM | #9 |
Well I just ordered a CCBEC. When the steering is unloaded (aka I am holding it in the air) Forward and Reverse works fine. So that makes sense, it is drawing too much. |
08-26-2009, 08:02 PM | #10 |
Where are you at - Houghton Mi? No LHS up there? I buy most things used, but LHS in Holland Mi. has CC BEC for $24 out the door. Before I bought my CC link, he would even program it for me. Default out of the box is 5.1v. It's good to go. If anybody you run with has a castle link, they could set it up to 6v for you, which is safe for almost all servo's, so you could squeeze a little more torque out of the servo. |
08-26-2009, 08:23 PM | #11 |
Nope, no LHS up here. Stuck ordering everything from ebay or towerhobbies or where ever. Shouldn't need to program it 5.1 is enough for bashing and recreational crawling. Thanks for the help |
09-02-2009, 11:23 AM | #12 |
Just an update. I got the CCBEC installed and working. Works great. Thanks to all who helped. |
