08-27-2009, 03:30 AM | #1 |
Quarry Creeper Join Date: Apr 2009 Location: columbus
| Help w setup of ccbec w 2 srvos bypasn rx
I want to run a CC BEC with two steering servo's and I want to bypass the receiver. I thinki have the basic idea of it. I just run the red and black from the bec to the servo's and abandon the signal wire from the bec and run signal wires from the receiver to the servos. And the only wires from the receiver to the servo's are signal wires. I then hook up the esc to the receiver normally. Is this correct ? If anyone could draw up a schematic on this for me I would be grateful. Thanks. Bob
08-27-2009, 04:54 AM | #2 |
RCC Addict Join Date: Jan 2008 Location: Lake Michigan
I have a sketch around here, maybe on my othe computer at work. If no one responds by mid morning, I'll look for it there. BTW, need signal and black neutral wire from Rx. Red and black from BEC. Could solder up a cleaner one, or use two "Y" cables sets from your LHS. |
08-27-2009, 08:46 AM | #3 |
Here is what I sketched a while back. If you use two Y harness', you would need two of them:
08-29-2009, 01:03 PM | #4 |
| dual servo bec setup bypassing the rx.
I am using the third channel to control the other servo.
08-29-2009, 01:12 PM | #5 | |
| sketch Quote:
08-29-2009, 02:08 PM | #6 |
Someone needs to chime in and concur or deny the following. What Slashbasher wants:
You need:
Only thing with this, is unequal positive and negative going to Rr(ch3) servo. But it should affect it. |
