08-30-2009, 03:08 PM | #1 |
Newbie Join Date: Jul 2009 Location: Phoenix
| servo wont throw a full 180degrees when powered.
i recently started to notice that my servo when powered will only throw left or right about 45 degrees off center left or right. even without weight on it. im running a castle bec set at 5.1v stock. through my rx. is it possible i need to run power directly through to my servo via connector or is something wrong with my servo? im running a hitech 645MG with a futaba rx and futaba t2ph tx. previously it would throw full lock to lock causing my tires to rub on my lower control arms but will barely throw to 1/2" from them.
08-30-2009, 03:13 PM | #2 |
That is normal. What did you change in your system?
08-30-2009, 03:20 PM | #3 |
oh ok. i wasnt sure if that was something wrong. i changed to a bta steering set up. i guess ill just have to mess with it and see what works best.
08-30-2009, 04:17 PM | #4 |
Rock Crawler Join Date: Feb 2008 Location: UK
You must've changed the geometry. Increase the servo travel (EPA) on your Tx (if it's a computer Tx), or use a longer servo arm.
08-30-2009, 04:30 PM | #5 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
I might be wronge, but most servos don't have 180* of throw. They usualy only have 90*, 45* each way. Some of the big power servos will advertise if they travel 180*. You can change the amount of travel on Hitec servos the the Hitec programmer, But the servo must be digital. Which means it would 4 numbers in the name of it. I hope this helps you in the future.
08-30-2009, 05:32 PM | #6 |
It sounds like the steering geometry was changed. See if your radio can give you more throw via EPA adjustment, and then you can tweak the servo arm length.
08-30-2009, 06:14 PM | #7 |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
Most servos can turn past 180 but are not set to do it on normal transmitter signals. A servo stretcher will allow the servo to go past 180. http://www.rcdude.com/servlet/the-13...retcher/Detail |
08-31-2009, 01:15 AM | #8 |
thanks guys i was thinkin about getting a new digital servo anyways. 110oz isnt really enough anymore with the weight ive added to the front anyways. might end up going to a jr or a hitech digital
08-31-2009, 02:38 AM | #9 |
No idea about the JR servos, but I think you need a Hitec 79xx servo and HPP-21 programmer. I don't think that you can change the resolution (to get more travel) with the 59xx servos. Best to check that the servo supports this feature before you buy.
08-31-2009, 11:47 AM | #10 |
thanks for the tip ill look into it in depth before i buy.
