08-31-2009, 12:08 PM | #1 |
Pebble Pounder Join Date: Oct 2005 Location: Rocklin / Ukiah, CA
| Ordering a Castle BEC. Quick ?
I am on Holmeshobbies website and I need to order the Castle BEC. I see that the most common voltage setting it 6V. I just want to make sure I order the correct voltage for my setup. I am running a ax10 with the following: Tekin pro 45t Tekin FRX Hitec HS-7955TG servo 3S 1500mah 25c lipo In the future I will add a second servo when I get a dig. Do you still suggest the 6v setting? I did search, but could not find my same setup. Thanks guys! |
08-31-2009, 12:14 PM | #2 |
Pebble Pounder Join Date: Dec 2008 Location: Alberta Canada
Yes 6v would be good .The nice thing about the castle BEC is you can set the voltage with the castle link on your own.
08-31-2009, 12:17 PM | #3 |
RCC Addict Join Date: Apr 2008 Location: Sacramento
08-31-2009, 12:33 PM | #4 |
Rock Crawler Join Date: Jan 2007 Location: Viroqua
Bought a used CC bec from a member he set it at 6v for me and I running an ax-10 with 1500 3s, rooster crawler esc (I know it shouldn't handle 3s, but it does very well for me so far.) novack 45t motor with 2 Hitec MG645's servos. This rig weights around 5# and runs real well with no glitches whatsoever, but it helps if you using a 2.4 radio.
08-31-2009, 12:45 PM | #5 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
6V is the way to go. |
08-31-2009, 01:49 PM | #6 |
Thank you guys. I just sent the order to Holmes.
08-31-2009, 01:51 PM | #7 |
Thank you sir! 6v is very good for just about any setup.
