Thread: Bec wire question
Old 09-01-2009, 10:23 AM   #1
Moderator Rule Breaker
eric113's Avatar
Default Bec wire question
Seems like everyone puts their power wires on the battery plug coming off the esc.
I have Tekin RS esc any reason not just to put the power wire's of the bec, on the battery post of the esc ?
eric113 is offline   Reply With Quote
Old 09-01-2009, 10:30 AM   #2
Nope, either way works. As long as the BEC is connected to the battery + and -, it will work. Be sure to remove the red wire on the ESC servo plug. Otherwise you'll burn up the esc.
Spiftacu1ar is offline   Reply With Quote
Old 09-01-2009, 10:37 AM   #3
I did that on my Tekin FXR, works just fine.
BigB_117 is offline   Reply With Quote
Old 09-06-2009, 04:39 PM   #4
can someone explain in detail how to hook the bec up up or post some pics
mesooners is offline   Reply With Quote
Old 09-06-2009, 06:23 PM   #5
As mentioned, BEC +/- end solders to battery plug along with ESC.
Jconnector end can go into the BATT terminal of the Rx, must pull red wire out of the ESC connector.
If you want it to power a single servo (High Torque steering servo) directly without powering everything else (ESC BEC can power the rest) then follow this. (ch 1 for steering servo)
sweli is offline   Reply With Quote
Old 09-06-2009, 07:27 PM   #6
Ultimate RC Decals
BOWTIE's Avatar
hey E thats what i did on my tekin B1R for the MRC..
BOWTIE is offline   Reply With Quote
