09-02-2009, 06:18 AM | #1 |
Newbie Join Date: Jul 2009 Location: Home
| Novak Rooster Killed my Lipo battery?
Hi, I installed Novak Rooster ESC 55 Combo on my AX10. I run 2s 4000maH 25C Lipo battery and now is dead because the Rooster did not cut-off in profile two. I followed the setup instruction and the manual says that after I press the one touch setup button then release I will get two leds light up at the same time then entering the profile mode afterward. One blink = profile one; Two blinks = profile two (lipo cut off mode) so I selected two blinks. After 25-30 minutes driving the ax10, it completely stopped. The ESC "Red & Green LEDs alternately flashing" didn't happen, the truck just went dead stop and the servo also didn't move. I checked the ESC profile again with a fresh lipo battery to make sure I selected the correct profile. And I did get two blinks (profile two) with the fresh battery. Do you guys know any known bugs in the Novak Rooster ESC? Have this ever happened to anyone?? I'm very dissapointed if that this happened from a name brand esc. Now I'm left with one dead lipo battery Last edited by roosterkill; 09-02-2009 at 11:59 AM. |
09-02-2009, 06:31 AM | #2 |
Are you sure that there wasnt a problem with the battery to begin with? I run a 1350 mAh 3S pack with a 7T puller and a lot of throttle and I get run times of about 40 minutes. Your 4000 mAh and 55T motor should be lasting MUCH longer than that.. BTW, it's ironic considering your username... |
09-02-2009, 06:32 AM | #3 |
Rock Crawler Join Date: Jul 2009 Location: talladega AL.
There is a guy on here Novaktwo find & contact him.
09-02-2009, 06:57 AM | #4 | |
Anyways, the battery wasn't fully charged and was used previously on my slash (with brushless/cut off capability also) plus I run the ax10 with 24T pinion and the incident happened when I run the truck in full throttle all the time on grass. | |
09-02-2009, 07:05 AM | #5 |
The first battery want take a charge at all ?? I know its lipo if its dead its dead.
09-02-2009, 07:09 AM | #6 |
You can bring a lipo back from a really low charge....just charge it on a low current under a NiMH setting until it hits 6V and then switch over to a lipo setting...
09-02-2009, 07:12 AM | #7 |
09-02-2009, 07:14 AM | #8 |
09-02-2009, 07:17 AM | #9 |
I know you ran it at full throttle. Did you have any glitching or warning the battery was getting low. It's supposed to stop but I read Novak instructions & if you keep running it it will kill the battery.
09-02-2009, 07:23 AM | #10 |
| I have successfully done this in the past. A buddy left his lipo plugged in (with a BEC) and drained it fully. We charged it with the method I listed above and he is still using it to this day. Note, we charged it out in the open and also used a LipoSack. Note #2, his battery was not puffed up in any way. If your battery is puffed, I wouldn't try this method.
09-02-2009, 07:33 AM | #11 |
| No glitching or warning.. just sudden stopped. And the servo was also non functional. As I mentioned on the previous post, I'm using brushless esc on my traxxas slash and I somewhat familiar with lipo cut off feature on an esc. I also understand after the function kicks in and leave it for a while I can still use the remaining juice that left in the battery, but I didn't do that with the rooster. The car just stopped instantly.
09-02-2009, 07:35 AM | #12 | |
09-02-2009, 07:43 AM | #13 |
RCC Addict Join Date: Dec 2005 Location: Tucson
Something dosen't sound right a axial w/55T and 4000 mah should drive for 3.5 hrs +. I went 1/2 hr to a 1.0 hr on a 35t hand wound w/1320 lipo
09-02-2009, 07:45 AM | #14 |
| I answered the same question by another gentlemen on this thread. the battery was not in FULL condition. It was previously ran on my traxxas slash
09-02-2009, 07:46 AM | #15 | |
09-02-2009, 07:54 AM | #16 |
Hate to see you ruin another battery but maybe the first one just died for some unexplained reason. Maybe you should try the other one. Just a suggestion.
09-02-2009, 08:28 AM | #17 |
09-02-2009, 11:00 AM | #18 | |
Rock Crawler Join Date: Feb 2008 Location: UK
If you really are using NiMH mode, your battery is seriously dead. BTW, I recovered an over-discharged LiPo battery just last week by charging it at 0.5A on a NiMH charger. | |
09-02-2009, 11:55 AM | #19 | |
09-02-2009, 12:04 PM | #20 |
Yes, it sounds like something is wrong with the battery other than low voltage. You should, no matter what the voltage, be able to charge it on NiMH setting.
