Thread: motor question from a noob
Old 09-02-2009, 10:47 PM   #1
Default motor question from a noob
I'm working on something odd, but the bottom line will be speed. I have 3 motors. 1 reedy MVP , 1 Traxxas stinger and 1 monsters of touring 19 turn double. Which would be the best to go fast?
Nylintbucket is offline   Reply With Quote
Old 09-03-2009, 06:23 PM   #2
First, you can throw that Stinker out... :?
I did a quick search and couldn't find out how many turns the MVP is, so if you can get that info go with the lowest turn motor, given your ESC can handle it. Or, just throw both motors in and see which is faster.
Greatscott is offline   Reply With Quote
Old 09-03-2009, 07:25 PM   #3
Yeah. Check the specs of your esc first if you have one already. check how low can it handle
CHRIZAD is offline   Reply With Quote
Old 09-04-2009, 09:39 AM   #4
I'm pretty sure the Reedy motor is a 27-turn stock motor. If your esc can handle it the 19-turn will the fastest, the 27 slightly slower and slightly more torque, and the stinger is just junk.
MississippiMudd is offline   Reply With Quote
Old 09-04-2009, 11:16 PM   #5
Default brushless motor questions for noob
does anyone know if you can use a 1/8 RC Brushless ESC 80A Sensored with a sensored motorsports due 10.5 brushless motor i did my seaching online and i havent found anything about it the esc can handle 7.4v ~ 14.8v 6s~12s NiMh or 2s ~ 4s Lipo and 3.5turns and up or 60turn brushless motor need help any can help me thanks
mysterygamer is offline   Reply With Quote
