09-03-2009, 02:24 AM | #1 |
Rock Crawler Join Date: Feb 2009 Location: On the "ROCKS"
| Futaba (S9157) Servo overheating
I'm just wondering if anyone else is having overheating problems with there Futaba S9157 steering servo. I have seen the temps run up to 158 degrees in just 15mins of run time. This has happend to, 2 rigs that I know of. The rig is a Berg and is running the following electronics!!! Motors/Holmes 45T Hand Wound , ESC/Tekin FXR , RX/Spektrum , Punk Rc Dig , Castle Creation/BEC 6.0v , Battery/Hypierion 1350mah 11.1V/35C Any input will help! THX!!! Last edited by SaxtonSlaughter; 09-03-2009 at 02:39 AM. |
09-03-2009, 02:35 AM | #2 |
RCC Addict Join Date: Jan 2005 Location: Germany north
09-03-2009, 02:36 AM | #3 |
Yep!
09-03-2009, 02:51 AM | #4 |
MFDesigns Join Date: Feb 2009 Location: ValleHOE
im running the futaba s9157 and no mater what batery i run it gets hot. my bec is at 6v and wired to the instructions, should i maybe run bec directly to cervo? i am one of the resons for this thread. |
09-03-2009, 03:14 AM | #5 |
Like a boss... Join Date: Feb 2008 Location: NorCal
Ummm....what happened between tuesday night and tonight? I asked you guys both about this tuesday when I was talking about mine! :-P I believe it's just your end points are off. I really like this servo and I've been running a couple of them on my ax10s for months, with no issues. I believe your end points need to be set lower than you think or are currently running. I' haven't had a chance to test since making the change but we'll see tomorrow night.. Last edited by mann0mann; 09-03-2009 at 03:19 AM. |
09-03-2009, 03:24 AM | #6 |
mfawv and I went to the falls tonight and his servo was running very hot. I believe his end points are set right, but its still running hot.
09-03-2009, 03:24 AM | #7 |
if my endpionts get any lower i cant turn. i went to the falls today and under all conditions it got hot, i ran three bats. thru and got hot every time. at one piont 140+. hotter than any other servo ive ran by a consideral amount, hitec 5955, and hobbieco. mike it hadnt gotten this hot when we talked the other night. i ran it tonight at my house and it got hot again. Last edited by mfawv; 09-03-2009 at 03:27 AM. |
09-03-2009, 03:28 AM | #8 |
Mike, what do you have your end points set at on the AX10's?
09-03-2009, 07:02 AM | #9 |
I have one on my super and it's great. I just know not to run for more than 20 minutes or so at a time. That's really no help but it's my fix. |
09-03-2009, 07:43 AM | #10 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
My Futaba's run hot too. I think wheel weight might play a small part in the heating, as the Hobbico in the SSS rig with lighter wheels seems to stay cooler, when run for about the same time.
09-03-2009, 11:40 AM | #11 |
My end point setting won't apply in someone else's truck. Linkage, servo arm, radio system will all affect those settings. I set endpoints first by visually looking for binding. On my truck I set it first by just backing off from getting into the springs or whatever mechanical limit there may be. Then I usually "listen" to the servo. You can hear a digital servo trying to work. I back it off more if it sounds like it's working the servo still. |
09-03-2009, 11:46 AM | #12 | |
This most recent servo I'm using on the berg though is noticeably warmer. Now I'll fall on my sword and admit, the first time I noticed the heat I did have some binding in my steering (totally my fault...the locktight got away from me ). The second time I noticed it I had been bound a bunch and admittedly it was working hard, and I feel like there may have still been some binding from the flex in my steering rod. I've since then, taking about another 10% more of steering out. I am not anywhere close to any mechanical limitation, so I'm going to give this one more shot tonight. I'm hoping it will solve the issue. May even go run today for a bit to test. | |
09-03-2009, 11:47 AM | #13 |
Hateraide Join Date: Dec 2008 Location: Mission BC
also make sure there is no binding that will be a big thing as well as epa
09-03-2009, 11:54 AM | #14 | |
My Futaba S9157 harldy warms up and I am running it above the recommended Voltage. I would say enpoints are key here. | |
09-03-2009, 01:35 PM | #15 |
Thanks 4 all the help fellas. Ill have to check out ur rig tonight Mike.
