09-03-2009, 01:32 PM | #1 |
Rock Crawler Join Date: Sep 2009 Location: Temecula Ca
| ax 10 Futaba mag 3pm 2.4g and goat crawler
I have every thang hooked up but when i turn it on it wants to run forward I set the trotle trim all the way back but still the same steering not working ether but it was working the night be for. keep in mind im a newbie
09-03-2009, 04:09 PM | #2 |
best i can say is they do that sometimes, first try unpluging the battery, then resetting the one touch and reprogramming after that. annoying hope they got that stuff fixed on the 3s. but they probably just threw in a useless bec instead.
09-04-2009, 01:04 PM | #3 |
| Well now im thinking
full throttle is now high speed and revers is now low speed. and now i have no revers. Ive never had this much troble with my Mini t's and t maxx or emaxx. Ok I got it My cannel 1 select all the setting are so messed up I moved up to channel 5 and all is good now. Last edited by rockn; 09-05-2009 at 01:27 AM. |
09-04-2009, 05:27 PM | #4 |
You need to calibrate the radio to the ESC, the calibration procedure should be in your ESC instructions. The first thing you are going to do is to set all of your trims back to zero. Help us to help you... Your post are hard to read, proof read them before you hit the "submit" button. |
09-04-2009, 07:21 PM | #5 |
| Dang
I'm not sure what I even wrote yesterday. Well All is well its all working fine now I moved the cannel up to five. 1's all jacked up. |
09-07-2009, 08:32 AM | #6 |
Newbie Join Date: Nov 2008 Location: Eden Prairie
Another thing if you are using the Goat 3S, the first profile is for the Worm Gear drives and I found that it rolled forward while in Nuetral throttle position. Once i switched it to profile 2 because I have a AX-10 then it worked perfectly. Just a FYI.
