09-04-2009, 11:27 AM | #1 |
Newbie Join Date: Aug 2009 Location: netherlands
| crawler esc or not
I have a carson dragster no limit esc on my axial and can crawl realy slow. Now I like to know what a real crawler esc has as an advantage. Thanks Ewoud |
09-04-2009, 11:34 AM | #2 |
Drag brake mostly. Maybe instant reverse or a better BEC
09-04-2009, 11:59 AM | #3 |
OK, what is a BEC
09-04-2009, 12:17 PM | #4 |
Rock Crawler Join Date: Feb 2008 Location: UK
BEC = Battery Eliminator Circuit. All car/truck ESCs, and most airplane ESCs, have a BEC that supplies the receiver and servos with power from the main battery. It eliminates the need for a separate receiver battery pack. The BEC on some ESCs can only handle 1 or 2 amps, not enough for a crawler. |
09-04-2009, 12:26 PM | #5 |
Pebble Pounder Join Date: May 2009 Location: South Gap
drag/hill brake. on some of the terrain i crawl its a huge + to have.
09-04-2009, 02:39 PM | #6 |
ok So how many amps do I need for a stering servo of 15 kg. How does a brake function when going of a hill Thanks |
09-04-2009, 05:19 PM | #7 |
Pebble Pounder Join Date: Sep 2008 Location: Carlsbad, SoCal
The drag brake will apply your brakes while the throttle is at neutral. So you can let off the throttle on an incline/decline and have your truck stationary instead of rolling away.
09-04-2009, 05:59 PM | #8 |
to be safe you need a castle creations BEC. it supplies 5A which is almost standard on crawlers anymore
