Thread: Axial ESC w/ 10 cells
Old 09-05-2009, 10:56 AM   #1
Default Axial ESC w/ 10 cells
What is the motor limit for the stock Axial ESC at 10 cells?
I know it's 27 turns at 6-cells, but I wanna max this puppy out
the_ghetto_rig is offline   Reply With Quote
Old 09-05-2009, 11:04 AM   #2
I would be willing to bet that your stock ESC can not handle 12V...
JeremyH is offline   Reply With Quote
Old 09-05-2009, 11:07 AM   #3
It's specs say it can handle up to 10 cells (12v)...
Old 09-05-2009, 11:35 AM   #4
The motor limit will be the same as motor limit is a measure of the number of turns that an esc can handle, not the number of cells. If your esc can take 10 cells (12v) then go for it
Nitro_Geezer_UK is offline   Reply With Quote
Old 09-05-2009, 11:52 AM   #5
True..But if I go up in voltage, I would need to go down in amp draw to not blow the speedo..E.G.: an FXR or Sidewinder can handle only 35T or higher at 11.1v-12v..thus my question remains: could the AE-1 handle a 35T at 11-12v as well? BTW, I have contacted Axial, but gotten no response yet..thanx in advance for the help!
Old 09-05-2009, 12:21 PM   #6
according to:
Axial's Website
It can handle up to a 15T motor... Max it out!
monkeyracer is offline   Reply With Quote
Old 09-05-2009, 12:37 PM   #7
Yep, you are right, I just checked Tower's website:
http://www3.towerhobbies.com/cgi-bin...?&I=LXULR4&P=7
I guess I would have lost that bet!
Old 09-05-2009, 12:59 PM   #8
max it out, if you fry it, they are cheap enough to replace.
Old 09-05-2009, 01:05 PM   #9
Then I'll split the cost of a new one with you!
Smoke effects look cool, but not pouring out of yer speedo..
I'm gonna play it safe and go 35T....
Thanx y'all!
Old 09-05-2009, 01:48 PM   #10
Thanx y'all!
I'm running 27T on mine now, with 2s LiPo, I'm thinking about going to 3s though, I'll let you know how that goes!
Old 09-05-2009, 01:51 PM   #11
Thanx man...
