Thread: hpi SF-1 servo made into winch?
Old 09-06-2009, 05:02 AM   #1
Exclamation hpi SF-1 servo made into winch?
hey i was just wondering if this servo would be able to be a winch?
thanks!
stampedecrawler is offline   Reply With Quote
Old 09-06-2009, 06:20 AM   #2
Just jump it!
rottenbelly's Avatar
You can make just about any servo into a winch. You just have to pull it apart and take out the stop. I did it with a extra hitech 225 mini servo.
rottenbelly is offline   Reply With Quote
Old 09-06-2009, 07:19 AM   #3
... and replace the pot with a pair of resistors.
clockworks is offline   Reply With Quote
Old 09-06-2009, 09:39 AM   #4
u dont need to replace the pot all u need to do is get it centered well and a dab of ca glue
benoj is offline   Reply With Quote
Old 09-06-2009, 09:56 AM   #5
OK - as long as you disconnect the pot shaft from the output shaft.
Old 09-06-2009, 08:45 PM   #6
can someone post a link or pictures on how to do this would be great
mysterygamer is offline   Reply With Quote
Old 09-06-2009, 11:23 PM   #7
http://www.rccrawler.com/winch.htm
zumzum5150 is offline   Reply With Quote
Old 09-07-2009, 02:41 AM   #8
this hpi servo is very different to my hitec 645 so i have no idea on what to cut,trim and glue on it?
i really need help on this servo!
Old 09-07-2009, 04:15 AM   #9
Take it apart and post some pics of the internals. It looks perfectly normal from the outside.
Old 09-07-2009, 04:40 AM   #10
hehehe i finally made it into a winch! it can only pivk up about 3-4kg but its fine for a recycled servo! now my next problem is where to mount it! i have no room at the front of the chassis a little in the middle buy loads in the back :(
i read/saw a pic of a winch what was at the back but used old rod ends to guide the line through?
any ideas or pics of a winch on a wk chassis?
