09-12-2009, 01:54 AM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: Canada
| Tekin FXR question
Well I went to order a Tekin fxr combo and found there is 2 versions, the regular and the pro version. Can someone tell me what the difference is and wether it's worth the extra money? I'd like to order it soon. Thanks |
09-12-2009, 02:05 AM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
the pro version motor is hand wound and better then the not the pro fxr esc has no motor turn limet i beleive |
09-12-2009, 02:09 AM | #3 |
Thanks. I'll try and dig into it a bit deeper.
09-12-2009, 02:36 AM | #4 |
fxr Controls: Forward/Brake/Reverse ON Resistance: 0.0012 Ohms Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor) BEC: 6.0V/3.0A Motor Limit: 13 Turn Throttle Profiles: 7 choices on board Reverse Type : 3 choices on board; none, delay, immediate Reverse Strength: 11 steps on board Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor Dimensions: 1.1 x 0.80 x 0.40 " (28 x 20 x 10mm) fxr pro Controls: Forward/Brake/Reverse ON Resistance: 0.0006 Ohms Input Voltage: 4-9 Cells, 2S Lipo (3S Lipo with 35T or higher motor) BEC: 6.0V/3.0A Motor Limit: None Reverse Type : 3 choices on board Reverse Strength : 11 steps on board Rock Crawler Spec: 3S Lipo compatible when used with 35T or higher motor Dimensions: 1.1 x 0.80" x .60" (28 x 20 x 15.24mm) Weight: 0.8oz (24g) |
