09-12-2009, 01:55 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: ?????
| hitec 7955tg problem. .. . help needed!!!
i guess the best way to xplain it, is sumtimes the servo goes dead silent and wont steer when it should, everything is plugged in correclty. i dono what it could be. im using a hitec 7955tg and a dx3r. .. . is this a common "fault," and has anyone else ever had this prob? thanks for any and all help working on getting the vid up now. .. . http://s652.photobucket.com/albums/u...t=100_1070.flv and in the vid you can hear it go silent. .. . Last edited by IDnewcrwlr; 09-12-2009 at 02:14 PM. |
09-12-2009, 02:12 PM | #2 |
Quarry Creeper Join Date: Aug 2009 Location: Palo Alto, Bay Area
plug in another servo of any type and see if it also "goes dead" at teh same time as the 7955tg. It;s possible you don't have enough power, and te reciever loses power / connection, and makes the servo seem dead. Do you have a BEC?
09-12-2009, 02:18 PM | #3 |
I wanna be Dave Join Date: Sep 2006 Location: Stuck on a Rig in the middle of nowhere Utah.
Also, what speed controler are you using?
09-12-2009, 02:23 PM | #4 |
| i tried it with another servo and i didnt have any issues, and where would the "losss of power" come from if my battery is fully charged and the connections are good? and yes i am running a bec. .. .
09-12-2009, 02:25 PM | #5 |
09-12-2009, 02:28 PM | #6 | |
The loss of power woudl come if your BEC can't handle the current. The 7955tg pulls a lot more current than lesser servos' WHich is why I said use abnother servo at THE SAME TIME, not replace the 7955. What I mean by this, is put another servo in the throttle slot WHILE the 7955 is still in steering channel. Tis very easy to lose power with a full charge if your BEC can't handle the current neccesary. Make sense? Did some googling, according to this link: http://www.rctech.net/forum/ask-hite...hs-5745mg.html the 5745 (which is less powerful than the 7955) can pull up to 4.8amps. The 7955 will be able to pull at least that much, probably more. The Sidewinder has a 3 amp BEC... EDIT: Reead my post and realized it seemed like i was shouting at you. FYI, i did caps to emphasize the important stuff, not to shout at you, lol. Last edited by Spiftacu1ar; 09-12-2009 at 02:41 PM. | |
