09-16-2009, 09:56 PM | #1 |
Quarry Creeper Join Date: Aug 2009 Location: Fresno
| FXR Brake Strenght?
Is it just me or is the FXR brake like a on/off switch? No matter how easy I get on the brake it just locks up the tires and sends my truck end-over downhill. The Drag Brake is awsome, but I would like to set my DB to a softer setting and use the brake for cutting speeds on decent. The neutral width is also a bit large, it makes the response feel 'laggy'. I know that to engage the brake I must hit it with-in one sec or I'll be in reverse. I can always compensate by running a higher DB setting but I'm not always on a hill where I want to stop when I let off the throttle, and push control isn't an option as it just delays the DB. Im running it in a SCX10 with a 35t and 3s lipo with a DX 2.0. Its really fustrating to just try and 'tap' the brakes only to get the result of my truck tumbling down a huge granite wall. . . Edit: My title is wrong, I am talking about brake strenght. Drunk Last edited by DrunkDriver; 09-17-2009 at 08:33 AM. Reason: Made a booboo |
09-16-2009, 10:27 PM | #2 |
Pebble Pounder Join Date: Apr 2009 Location: Renton
The hotwire will let you program all of that very easily. Otherwise, you have to use the two buttons and should be able to adjust them to some degree as well. SS |
09-16-2009, 10:33 PM | #3 |
Rock Crawler Join Date: Sep 2006 Location: Lititz
I use the higher drag-brake setting and program the FXR to go to reverse immediatally, No brakes-----Less throttle = brakes. Not sure why it would matter if your on a hill or not when you want to stop. |
09-16-2009, 10:41 PM | #4 |
Quarry Creeper Join Date: Aug 2008 Location: Texas border crawlin from cops
Check the manual on the FXR and try playing with the increment button. I guess from setting 1(softer) up to 5 or 6 which is the strongest. Its a matter of trial and error.
09-17-2009, 05:21 AM | #5 |
RCC Addict Join Date: Jul 2008 Location: Sin City
I just got my FXR's and hotwire because i heard they had better drag brake than the castle's. I'll have to play with the hotwire if they are that strong.
09-17-2009, 08:01 AM | #6 | |
I wanna be Dave Join Date: Feb 2009 Location: 20 miles southeeast of downtown Sacramento
09-17-2009, 08:58 AM | #7 | |||
I am running this in a scaler, not a comp rig. Sometimes I do want to go fast on flat surfaces without the high DB setting so when I do let off the throttle my truck doesn't just lock up. I have tryed messing with the push control setting but it just isn't good because it just delays the DB, so the molment I get back on the rocks I have a laggy set up. My Novak Rooster had fantastic brakes, but it can't handle the 3s lipo's I'm running. If someone could just tell me if brake strenght is customizable with the hotwire I would know what to do. Drunk | |||
09-17-2009, 09:05 AM | #8 | |
Thanks to all for the time. Drunk | |
09-17-2009, 09:10 AM | #9 |
You can adjust brake strength via the Hotwire. There are 2 options - Brake Strenght and Drag Brake. SS |
09-17-2009, 09:24 AM | #10 |
Relaxed ! Join Date: Apr 2009 Location: On the road again !
09-17-2009, 09:34 AM | #11 |
Quarry Creeper Join Date: Mar 2008 Location: Raleigh, NC
You are using the delayed rev. setting. I think you should try the Fwd-instant Rev. setting (no delay). Its really hard to use the brake feature in a crawler, Just trust the drag brakes ! |
09-17-2009, 11:15 AM | #12 | |
I know I can just use the drag brake, but thats not the goal, this is more than just a crawler, it goes fast too Love the esc, and 3s Lipo is stupid fast Drunk | |
09-17-2009, 10:53 PM | #13 |
Rock Crawler Join Date: May 2008 Location: Sumter, SC
You can always control the "travel" of the brakes with your radio. My DX3R lets me control the % of brakes just like D/R steering. It works great on my nitros and Slash. Just another wrench to throw into the problem! |
09-17-2009, 11:09 PM | #14 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
| x2 having a good remote with a lot of adjustments helps get rid of a lot of tuning problems. then you only need to get your esc close and the fine tuning can be done on the remote.
