09-21-2009, 08:48 PM | #1 |
Pebble Pounder Join Date: Aug 2009 Location: Orygun
| Axial Electronics
I had a Axial Rock racer now going scale, long story short took my electronics out of the rock racer mounted them on the scx10, and the esc is showing red and green flashing lights, i have all the stock axial electronics with a Integy 55 or 65T motor...yes all electronics worked before putting them in this truck...
09-21-2009, 09:03 PM | #2 |
If you get red flashing when engaging forward/reverse and green in neutral, that's normal operation If you get anything else I'd suspect something is wrong |
09-21-2009, 09:34 PM | #3 |
its flashing red then green not doing anything...its unresponsive
09-22-2009, 05:56 PM | #4 |
would the steering servo going out cause this problem? because when its on the steering servo makes a wierd buzzing sound the whole time and i have adjusted the trim too
09-23-2009, 07:28 AM | #5 |
I wanna be Dave Join Date: Oct 2008 Location: Golden
you probably flipped the esc connector into the receiver. flip it back the other way, and it will work fine. The servo making noise is normal depending on what servo you use. |
09-24-2009, 08:51 PM | #6 |
DOH thanks for all the advice the esc was plugged in backwards
09-24-2009, 09:24 PM | #7 |
No problem. I've done that a few times, and what is funny is right after I posted that in another thread, I plugged it in backwards. Wish there was an easy way to remember which way is which.
