09-28-2009, 02:26 PM | #1 |
RCC Addict Join Date: Oct 2008 Location: PA
| Scale Lighting
Looking at this lighting kit: http://www.tcscrawlers.com/Yeah-Raci...2-p-16809.html My question is, do I need a second battery or can I just plug it in to my 3rd channel spot on my receiver. I have a big offroader 2.4GHz Tx/Rx, so the 3rd channel is an on/off switch. Thanks! |
09-28-2009, 02:37 PM | #2 | |
Quarry Creeper Join Date: May 2008 Location: Ontario
If im wrong, someone correct me | |
09-28-2009, 02:44 PM | #3 |
Thanks, is that the B/C on the receiver? How and what do I need to use. Never used one nor really know what it is.... Thanks! |
09-28-2009, 02:53 PM | #4 |
If it helps, I probobly wouldn't use the Amber lights. So I'd only run 3 sets instead of 4.
09-28-2009, 03:28 PM | #5 |
09-28-2009, 03:56 PM | #6 |
Eh, not sure I want to do that now lol
09-28-2009, 04:09 PM | #7 |
Pebble Pounder Join Date: Oct 2007 Location: gig harbor
i had a set of those on my rig for awhile. i cut the end off and used a seperate 6volt battery pack for it. for those lights a bec would just hook from your exisiting battery and the other end you would use the positive and neg and leave out the signal wire and hook it up to the lights. and then set the voltage to 6volts, i think from the factory it set to 4.8volts. later g Last edited by ggooler; 09-28-2009 at 04:11 PM. |
09-28-2009, 04:36 PM | #8 |
Is there a system out there that doesn't require a BEC?
09-28-2009, 06:04 PM | #9 |
| Yeah the Holmes Hobbies Torquemaster BR-XL http://holmeshobbies.com/product.php...4&cat=2&page=1 |
09-28-2009, 06:12 PM | #10 |
I have a brand new rooster lol. Guess I'll put the money somewhere else haha. Thanks guys!
09-29-2009, 12:42 AM | #11 |
Rock Crawler Join Date: Feb 2008 Location: UK
An LED draws around 20 milliAmps, so this lighting set will probably draw around 200mA in total. That's a fifth of an amp. I doubt that it'll make much difference to the total Amp draw. If your truck works OK without an external BEC, adding these lights should be fine. |
09-29-2009, 08:00 AM | #12 |
I was wondering that because in a review on a site that sells them, the guy's review said you just plug it into the the reciever and go. Plus my 3rd channel is a on/off switch, so it won't affect anything when they're off (like when it's sunny out lol)
09-29-2009, 11:09 AM | #13 |
Think I might go with this set up. Simpler and cheaper..... http://cgi.ebay.com/6-Rc-Led-Headlig...d=p3286.c0.m14 |
