12-03-2005, 09:42 AM | #1 |
Pebble Pounder Join Date: Oct 2005 Location: The arm pit of the universe
| Battery dumping early
Ok, I'll explain the best I can..... On my monster truck, the battery will last a couple of laps and then peter out. I have just installed a new 19t motor. With the 27t motor it didn't happen. The endbell keeps coming loose and I have turned the com, installed new brushes. I think the end bell keeps hanging a brush. Is it possible? How do you fix that? |
12-03-2005, 11:01 AM | #2 |
I wanna be Dave Join Date: Feb 2005 Location: Burnsville
If you are comparing your runtime between your 19 and 27 turn motor, then it could be the lower turn motor that is causing it. The 19 turn motor draws more amps than the 27 turn, and thus a lower runtime.
12-03-2005, 07:37 PM | #3 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
also the timing is most likely off and needs to be set correctly.at 0 degree front and rear.if you want to give timing the rear motor gets reversed timing.but start at 0 degree first then go from there.with 3000 packs i just make 5 min in a race
12-04-2005, 01:32 PM | #4 | |
I make maybe 4 or 5 laps with the 19t and it dumps. | |
12-04-2005, 02:45 PM | #5 |
Newbie Join Date: Dec 2004 Location: verona
Make sure the timing is 20 degrees advanced (not retarded) on a standard rotation motor. If the endbell comes loose you may not have the internal ring that the endbell screws go into indexed properly. How many minutes is a couple of laps? What batteries are you running?
12-04-2005, 04:38 PM | #6 |
Did you change your gearing when you switched from the 27 to the 19?
12-04-2005, 07:10 PM | #7 | |
By the way, this is just a test oval I am running my truck on. | |
