10-16-2009, 04:45 PM | #1 |
Pebble Pounder Join Date: Feb 2009 Location: Farmington,Nm
| mamba 25 x combo
has anyone ran two 2s lipos in this, this is the discontinued version. i dont want to burn up my speed control but i want to go fast. and the motor is the 1/18th 8000kv brushless motor. Moderators please move if needed. Thanks Tyler |
10-16-2009, 05:21 PM | #2 |
Pebble Pounder Join Date: Nov 2006 Location: vaca, nor cal
My mamba 25 Has been fine running 3 cells just fine. I have it on my rc28mt with the 6800 and it goes like a bat out of hell...
10-16-2009, 08:47 PM | #3 |
No 2 2s lipos dual batteries
10-16-2009, 09:17 PM | #4 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
are you goin to run these in series (to basically make a 4s lipo) or paralell just go get longer run times?
10-16-2009, 09:26 PM | #5 |
series in my mini erevo. i ran 2 stock batteries and it gets HOT. so idk if i should even try it.
10-16-2009, 10:32 PM | #6 |
10-16-2009, 10:49 PM | #7 |
Tire&Foam Extraordinaire Join Date: Jun 2007 Location: C.I. Compound, Tyler, Texas
You need to run it with a CC BEC. One of my Mamba 25's would get hot and shut down on 3S. But once I installed the CC BEC, it worked perfect. 2S in series or 4S in a lot to put through that little ESC. I run a Mamba Max on 4S in my mini e revo. It blew out the rear diff in no time flat. Like within 2 battery packs. It's back flip heaven and crazy fast.
