10-16-2009, 08:12 PM | #1 |
Newbie Join Date: Oct 2009 Location: menomonie
| on/off switch help
Hi my ax10 has a little blue esc that has no on/off switch I was wondering if there was a way to put on in the red,white,and black wires from the esc to the spectum receiver without recking anything.Eric
10-16-2009, 08:42 PM | #2 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Generally the black wire on the 3-wire connector goes along the outside edge of the receiver.
10-17-2009, 04:31 AM | #3 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
Why do you need an on/off? plug the battery in it turns on, unplug it it will turn off. Most esc's pull power anyways when you leave the battery plugged in, I don't run an on/off on any of my cars because it isn't needed. plus it helps to remind me to unplug my lipo's
10-17-2009, 10:17 AM | #4 |
I've always cut the switches off the ESC's I've run. I feel unplugging the battery is allot better than having a switch. Less mess in the chassis,less wire to worry about. Regardless of what battery type,I've always unplugged my batteries if the car is going to sit for more than 5 minutes. |
