10-17-2009, 04:17 AM | #1 |
Quarry Creeper Join Date: Sep 2007 Location: NE Ohio
| Wet Servo Issue
I have a Hitech 645mg Servo and I believe that my steering servo got a little too wet yesterday and now after trying to dry it out, all t does is kindof pulsates and only does it in one direction, trying to turn right. Also I get no speed control function as well, would a bad servo cause issues with ESC where it wont go forward or backward??? Any help or ideas, or is it a good chances the pots are messed up and better off replacing servo?? Chris Last edited by snwchris; 10-17-2009 at 09:39 AM. |
10-17-2009, 09:44 AM | #2 |
Rock Crawler Join Date: Mar 2009 Location: West of Eugene, OR
I'd open up the servo and let it air out; don't apply any more power for a while. You might try gently spraying it out with an air compressor, etc... If your battery is low forward/reverse may glitch or not go at well when trying to also power the servo...? Hopefully your ESC didn't get wet as well. What's your setup? |
10-17-2009, 11:34 AM | #3 |
Running a Novak Rooster Crawler & 55T Motor as well as a Venom 2s Lipo. The battery is almost fully charged, only has about 30mins of run time. Today at the local hobby shop tried a few things and almost seems like the ESC has the glitch, but didn't get wet. We bypassed the ESC with a battery pack pluged into the receiver and the servo worked fine. When I unplugged battery pack and plugged the ESC back into the receiver it glitches. Chris |
10-17-2009, 11:46 AM | #4 | |
Have you made sure the receiver is dry? How long was in wet while the truck was turned on? Quite possible you could have a bad receiver. What ESC do you have? No more than a 645 is worth,I'd just replace it. | |
10-17-2009, 11:52 AM | #5 |
Running Novak Rooster Crawler ESC It ran for about 2mins after it got wet and then acted up. I let dry yesterday afternoon and overnight and stilll no response. I pulled the case on the receiver and let dry as well. |
