12-07-2005, 05:11 PM | #1 |
Rock Stacker Join Date: Nov 2005 Location: Indiana
| Bluebird servos
Has anyone ever used these? Better yet, heard of these? They say they have 190oz. of torque @ 6V? Im thinking about getting them.....unless you guys talk me out of it. |
12-07-2005, 05:19 PM | #2 |
Quarry Creeper Join Date: Nov 2004 Location: MANVILLE
i have some.they are ok for me.i haven't had any problem with them.but others did have issues with them.if you do a search you'll find a good # of posts about them.i bought them when they where $24.95 so as far as i'm concerned it's you get what you pay for.i use servo savers on all my rigs.some of there issues may be from not using savers
12-07-2005, 06:05 PM | #3 |
RCC Addict Join Date: Apr 2004 Location: Cincinnati Ohio
I've bought 3. 2 of them burnt the electronics up, and one of them the gears stripped. So I took the 2 burnt ones and made one good one using the gears.
12-08-2005, 01:07 AM | #4 |
Quarry Creeper Join Date: Aug 2004 Location: HP lounge
I've had good success with the ones I have, but they weren't in crawlers. That said, a 1/8 scale buggy and a Twin Force aren't exactly kind to servos either.
12-08-2005, 04:50 AM | #5 |
Pebble Pounder Join Date: Dec 2005 Location: Somewhere in Sweden
They is both cheap and good I have heard!:-P mr_svensson, here on forum have such in his TXT-1 and he is ever so pleased over them! |
12-08-2005, 10:28 AM | #6 |
Quarry Creeper Join Date: Feb 2005 Location: Indy-Westside
Trust me...they suck!!! You might have better luck...but I doubt it.... |
12-08-2005, 10:44 AM | #7 |
Pebble Pounder Join Date: Feb 2005 Location: Flagstaff
I agree they suck! |
12-08-2005, 11:10 AM | #8 |
Rock Crawler Join Date: Dec 2004 Location: www.ORCRC.com
I think over the last year I have bought 7 of them for myself (5 standards {BMS-630MG} and 2 heat sinks {BMS-660MG}). I have 2 buddies that have also probably another 6 or so of the standard ones. I have killed the electronics on 3 of them (2 just quit working and one caught fire) I have stripped two sets of gears I now have two good work ones and I just sold two. Plus I'm now running kimbrough 124 servo savers which has stopped most of the failures for me (gears and electronics). One buddy of mine has stripped the gears once - and 1 electrically failure. Another buddy has stripped 2 sets of gears and 2 didn't work out of the package. On most of the gears sets listed above that have stripped where repaired using parts from the ones with bad electronics. BTW the new metal heat sinks servos look a bit nicer on the inside and have different electronics. |
12-08-2005, 12:29 PM | #9 |
Survey says!!!! They SUCK! Now I know what not to buy. I am running cheap Tower Hobbies High Torques servos now (becasue Im broke!) and I am looking for a upgrade......what servos are you guys running?
12-08-2005, 02:59 PM | #10 |
Pebble Pounder Join Date: Dec 2004 Location: Richmond,VA
| I purchased 2 of these and they are doing great so far. http://www2.towerhobbies.com/cgi-bin...?&I=LXNZ36&P=7 . |
12-09-2005, 06:46 PM | #11 |
Quarry Creeper Join Date: Oct 2004 Location: Hopkinsville
I would recommend NOT wasting your money on them. I bought 2, one worked, one didn't. Sent the broken one back and they replaced it but included a letter blaming me! Ine of the gears is a 2 piece unit that's pressed together, I replaced 4 of them before they finally smoked. Go 1/4 scale.. the Hobbico cs-80 is almost as cheap, almost twice the torque. However... they are as large as a pack of ciggs.. Heavy |
