10-21-2009, 07:11 PM | #1 |
Rock Crawler Join Date: Mar 2006 Location: Arrowhead Diggin
| Balancing lipos
When you're going to balance lipos do you plug in the balacer first, before charging? Can you balance your lipos even when your not charging them?
10-21-2009, 08:58 PM | #2 |
Quarry Creeper Join Date: Aug 2008 Location: Texas border crawlin from cops
charging and balancing plugs are too be hooked in order to balance it. When youre balancing it, its charging at the same time so its will be working both ways.. Hook the balancer plug first then the deans and lastly, turn on your charger and set it to balance lipo option then youre set
10-21-2009, 09:31 PM | #3 |
I charge through my balancer. |
10-21-2009, 10:00 PM | #4 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
I use common sense rc balance pro to balance my lipos while I charge them on the onyx 230 charger...you can also use the balancer with out charging...hook the balancer up to the lipo first, then to the charger. no you don't have to use deans to charge, most do...but you don't have to....... |
10-21-2009, 10:14 PM | #5 | |
10-21-2009, 10:52 PM | #6 |
10-21-2009, 11:08 PM | #7 |
bingo! guess we need to know that then.
10-22-2009, 02:08 PM | #8 |
I was givin a little Thunder power charger and a balancer. Each are separate.
