11-01-2009, 03:17 AM | #1 |
Pebble Pounder Join Date: Sep 2009 Location: On tour in Iraq!
| No Tekin Team Driver Setup Sheets for Crawling?
Now I know there is at least one Tekin driver out there with a rock crawler. So how come when I go to the Hotwire page http://www.teamtekin.com/hotwire.html and click on the Team Setup Sheet link http://www.teamtekin.com/hotwire/ESCsetups/index.html there are no Crawler sheets listed? Talk about being a second class citizen and all! (Kidding! Kidding!) Actually there are only sheets for the "R5" ESC... why no FX and FXR? |
11-01-2009, 08:13 AM | #2 |
Because setup varies wildly depending on the parts being used. There is no one "hot" setup.
11-01-2009, 09:35 AM | #3 |
Rock Crawler Join Date: May 2006 Location: Georgia
These are the setups I start off with. SCX-10 FXR/35T Berg Dual FXR/55T Front: Rear: Only differance is more Drag Brake on the rear. Losi CC Dual FXR/45T MOA. Used same setup on both F and R Losi CC RS/21.5 14T Pinion SCX-10 RS/21.5 15T pinion. Keep a close watch on motor temps when using the timing Boost. For a heavier rig its better to use a bigger pinion and 0 Timing Boost FYI I run a small Neutral Width on all of my rigs. A higher Neutral Width may be needed to program the ESC with some radios. |
11-01-2009, 11:27 AM | #4 |
I wanna be Dave Join Date: Nov 2006 Location: spring hill TN
Whats Brake Strength?
11-01-2009, 12:01 PM | #5 |
11-01-2009, 12:07 PM | #6 |
Rock Crawler Join Date: Feb 2009 Location: Surprise, Az
I have mine set up with brake strength off and drag brake on 30 for the berg. Strong enough to lock it up with an original punk dig switch. Figured brake strength would only help when using forward/brake or forward/brake/revers... |
11-02-2009, 09:39 AM | #7 | |
This is great! Now we just need to convince Tekin to post them on the website! | |
11-02-2009, 09:51 AM | #8 |
11-02-2009, 06:20 PM | #9 |
Pebble Pounder Join Date: Mar 2008 Location: El Dorado Hills, Ca
I'll get one of our "guys" to make a FXR crawler setup sheet. I think that's a good idea and apparently so do you guys! LOL
11-02-2009, 06:58 PM | #10 |
11-12-2009, 07:48 PM | #11 | |
Quarry Creeper Join Date: Oct 2008 Location: A little town called Dallas
Im using the Hot Wire with a single FXR Pro in my Berg and my Hot Wire screen doesnt give the same options as yours. What am I missing? | |
11-12-2009, 07:50 PM | #12 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
11-12-2009, 08:48 PM | #13 |
Got it now, Thanks for the help |
11-23-2009, 05:14 PM | #14 |
Quarry Creeper Join Date: Jul 2008 Location: Newark
11-23-2009, 05:17 PM | #15 | |
Both? I only run one ESC. I am guessing that your running 2..... Might be your neutral width setting......I have never had that problem personally though. | |
11-23-2009, 05:29 PM | #16 |
One thing to look at is make sure you set your ESC's to the radio at the same time not one then the other . On my dual ESC setup I also run alot more brake on my rear ESC. |
01-08-2010, 02:44 PM | #17 |
I wanna be Dave Join Date: Dec 2008 Location: ?
