12-12-2005, 08:01 AM | #1 |
Pebble Pounder Join Date: Oct 2005 Location: The arm pit of the universe
| PLease help, bad glitch.......
I have BAD glitch and I need help fixing it. Here is what I have.... S Rooster with motor wires twisted per Novak instructions Modded TQ3 and receiver 55t Lathes Here's a quick pic of the set up..... I have tried new crystals, changed receivers and moved the rx to the very back of the truck, tried a new speed controller, unplugged both servos and straightened the antena wire out. All of that netted the same results, it goes into convulsions and is completely uncontrollable. I tried my DSM/M8 setup and it ran perfect. I am assuming it is the radio since that is the only new item in the equasion above. Any takers? |
12-12-2005, 09:25 AM | #2 |
you have already done the troubleshooting for us! If it works perfect with another radio then your esc and servos are probably golden. There might a bad peice on your reciever or transmitter. Have you tried switching out either? You have changed the crystals, which was my first guess. I say loan a reciever for a bit and see it it's still unusable.
12-12-2005, 04:24 PM | #3 |
I swapped out a rx and it still glitched. Can a radio just go bad like that?
12-12-2005, 04:50 PM | #4 |
try swapping out the transmitter whilst using your old reciever and you shall get your answer I have an old radio that doesnt steer all the way. The throttle is fine, but the steering is like 10% of what it should be. |
