11-04-2009, 05:14 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Ukiah
| double motor crap
I have a two part question. If the motor smells burnt but runs should i scrap it anyway? The motor gets extremly hot after mabye 30 seconds of running, is it the motor or other parts? The questions are for different motors. Yesterday sucked bad |
11-04-2009, 05:20 PM | #2 |
Burning smells are bad. The first one is probably toast. The second one could be on its way. Pull the motors and make sure everything in the drivetrain spins like it should. If something is dragging or bound up, it will put too much stress on the motor and fry it. Also make sure you don't have your gear mesh set too tight. |
11-04-2009, 05:25 PM | #3 |
Thanks for the quick answer. I think im gonna pick up two new motors just to be safe |
11-05-2009, 07:50 AM | #4 |
Quarry Creeper Join Date: Dec 2008 Location: Suburbs
seems like it has a short...when i first wound a motor I didn't connect one of the tabs on the comm correctly and the motor got really hot really fast...so I would say that the motor is probably bad and its cheap enough to buy a new one...plus the heat is going to effect the magnets...might not be enough to kill them but compared to a fresh motor you will have less torque and less drag brake available. I would scrap them and buy new. peace of mind
11-05-2009, 09:39 AM | #5 |
I got new motors in one of them the spur gear had striped and two of the teeth got in the motor and somehow took out a brush. The other is just burnt |
