11-07-2009, 08:06 PM | #1 |
Rock Crawler Join Date: Feb 2006 Location: Where the foams are always wet
| Futaba 3PM Modded for 3 Position Switch
I made this mod to my controller a while ago. And since then I have had some interest from my friends on modifying their controllers too. So I took some step by step pics on how to add a 3 position switch to a Futaba 3PM Here is my controller with the switch added in. The switch is spring loaded, first click is programmed for freewheel, then pushing it in all the way is rear axle locked. Step 1: Remove the 7 screws from back of controller Your controller should look something like this inside... Step 2: Remove electronics Don't forget these little two screws underneath the circuit board on the steering pot You now should have an empty case Step 3: Mark and drill case for switch Switch out of a Mercedes C-class window switch group I used a uni-bit, came out looking like this... Slowly and carefully make the hole just big enough for the switch to fit in tightly Step 4: Route wiring (I used phone cord) Make sure none of the wires from the switch short out to each other. The first click on the switch closes the inner contacts (blue wires) when pressed fully both sets of contacts are closed (blue and orange) Inner contacts (blue) get soldered onto SW2 switch shown here Second set of contacts (orange) get soldered onto Cond2 switch It should look something like this afterwards Step 5: Re-assemble I tacked the switch in place with some CA glue. Then for final appearance run a bead of black epoxy around the switch This one took me about and hour and a half... So all in all, not that hard of a modification! :-P Feel free to ask questions! TOM |
11-07-2009, 08:22 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
nice mod but you left out the specific pics and info on the orange/white wires,,ar ethey at the bottom of the last open case pic?
12-28-2009, 03:05 PM | #3 |
Pebble Pounder Join Date: Jul 2009 Location: Woodburn
hey, this is MY RADIO!! LOL Tom is the man. How he thinks of this sh!t is beyond me..... |
12-28-2009, 05:36 PM | #4 |
RCC Addict Join Date: Feb 2006 Location: ccxc
i just run mixing on mine and it works fine........mode2 is freewheel mode 1 sw2 back is 4wd and forward is locked.
01-19-2010, 04:51 PM | #5 |
Rock Crawler Join Date: Oct 2009 Location: Wasilla, Alaska
Will this work with a standard 3 position switch, if so where does the fourth wire go? or can i just replace the two position switch on the board with a three?
01-20-2010, 01:13 PM | #6 |
01-21-2010, 08:24 PM | #7 |
Thanks, that would be great |
01-28-2010, 11:21 AM | #8 |
Did you find out anything yet?
01-28-2010, 01:27 PM | #9 |
am texting him right meow...
01-28-2010, 01:35 PM | #10 | |
So I'm not sure what you mean by "standard" 3 position switch. But the switch I used works as follows: Push it to the first detent and one set of contacts go from "open" to "closed". Push it to the second detent and the first set of contacts stay "closed" and the second set of contacts go from "open" to "closed" I have a couple more of these switches left. If you want I can mail you one for N/C TOM | |
01-28-2010, 02:15 PM | #11 |
Newbie Join Date: Jun 2008 Location: Saginaw
Im sure doing this would void the warranty on my radio though! I have been looking at the 3pmx, but does it actually have a switch for a dig unit? They dont make it very clear. |
01-28-2010, 02:30 PM | #12 |
I could care less about warranty... If this radio breaks I will just buy a 3pk or 4pk so I can still use my recievers The 3pm-x has newer software that allows you to program the "DT3" or "DT4" switch for use of dig or rear steering. They are both 3 position "trim" switches. TOM |
01-29-2010, 06:29 AM | #13 |
Quarry Creeper Join Date: May 2008 Location: Ontario, Canada
01-29-2010, 07:38 AM | #14 | |
08-19-2010, 11:47 AM | #15 |
RCC Addict Join Date: Mar 2009 Location: Chilton
Any way this will work with a small 3 pos toggle like what people are useing on the tq3 controllers? I have no idea where I could get one of those switches like you from around here.
08-01-2017, 09:31 AM | #16 |
Newbie Join Date: Oct 2008 Location: Portugal
| Re: Futaba 3PM Modded for 3 Position Switch
Hi, I can't see the photos on the beginning... Can any one help me? Can any one send me please the photos, or how to do the modd? Thanks, Miura73 |
