11-14-2009, 05:58 PM | #1 |
Rock Stacker Join Date: Apr 2009 Location: Glendora
| Novak Goat Issue
Hey guys, I have a Novak Goat in my Timberwolfd, my son was driving it the other night and he came in and told me the battery was dead. I gave it throttle and it didnt make a noise or even move but the steering worked. I turned the wheels about 10 times and it seems fine but it still wouldnt drive. I shut off the switch and turned it back on and then it worked perfectly. Battery was fully charged so that wasnt the issue. Only time it has happened, but I have not driven it since. Any ideas?
11-14-2009, 06:38 PM | #2 |
i can't explain it, but mine has done that several times. i ended up blaming heat and added the fan.
11-14-2009, 08:17 PM | #3 |
Did that solve the issue? i think I am going to install me telemetry temp from my DX3S to it and see if thats an issue. Maybe I dont have my mesh right on the R2.
11-14-2009, 08:44 PM | #4 |
i think it did, i've had so many issue's with my goat it's hard to remember what fixed what.
11-14-2009, 09:13 PM | #5 |
Really, thats not good. Care to share?
11-14-2009, 09:31 PM | #6 |
glitching, shutting down, heat, turning into a sport ESC with no drag and a double tap for reverse, taking off full throttle at random and not having neutral at neutral no matter how many times i did the one touch. since i added the fan, a CC BEC and got a 2.4 radio i've only had glitching issue's once, the full throttle deal once and a odd deal where it would cut out under full throttle at the last comp i went to. AM was a nightmare, really undriveable (for comps anyways). and i hate how the dragbrake works, it needs to be stronger at part throttle and ramp up slower. i now remember the worst it got with the issue your having now was when i switched from hammers to rovers without gearing down, going 3 teeth down on the pinion helped and the fan cured, a strong setting on the drag brake will cause major heat if you let the rig set still also. |
11-14-2009, 10:27 PM | #7 |
11-14-2009, 11:26 PM | #8 |
11-14-2009, 11:32 PM | #9 |
Pebble Pounder Join Date: Oct 2009 Location: Perrysburg
I have had this problem also,I think it is some sort of "over volt" problem.
11-14-2009, 11:38 PM | #10 |
11-14-2009, 11:49 PM | #11 |
I thought this because i have had a "stall" when i first turn mine on a few times,But after the first amp draw it works fine.
11-15-2009, 07:22 AM | #12 | |
I've thermalled my 3S Goat at 159 degrees. Turned it off for a few then back on and was good to go. Quote:
In Sport mode is was likely just the natural drag of the motor and gear reduction of the drivetrain. | |
11-15-2009, 10:18 AM | #13 |
Wow, a lot of good info for me here. I will look into a fan but I want to see what my temps read when I go crawl. Thanks for the input.
11-15-2009, 02:35 PM | #14 | |
when it went in sport mode it flew downhill, thats how i figued out there was a slight drag in crawler mode. if they add ramp and drag adjustments when they add the novalink to the 3s unit it will perform well IMO. | |
11-15-2009, 03:51 PM | #15 | |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
I would get yourself a Mamba Max Pro..Has alot less isues,and comes already compatible with Castle Link so you can tune your esc,plus no need for a bec.. | |
11-15-2009, 06:10 PM | #16 |
I keep hearing that and I may go that way when I build my Bruiser.
11-16-2009, 12:11 AM | #17 |
Quarry Creeper Join Date: Oct 2008 Location: Valley Village
Hey guys. What gearing are we usin on our Goats. Im usin 20/87 (pinion/spur) is that right? I use a fan during the day. 14/87 got hot on me. Does this sound right?
11-16-2009, 02:23 PM | #18 |
16/87 thermals on mine pretty quick, i run 13/87. 18.5 on 2s
11-16-2009, 07:47 PM | #19 | |
Quarry Creeper Join Date: Mar 2006 Location: SoCal
Our upcoming M2 Dual 3S brush controller will be the first Novak esc released with the PC interface. It can also be set up for single brush motor operation. Our Kinetic 2S Racing controller will be released next; then we will re-design the other controllers that we plan to continue offering. We are also finishing up our Kinetic 4S; wonder if Crawler specific BL controllers will even be necessary? Kinetic programming features: Multiple adjustable parameters via on-board or optional PC interface: Minimum Brake, Drag Brake, Minimum Drive, Dynamic Timing Advance™, Electronic Power Control™, Dead Band, Throttle Curve, Brake Curve, Brake Frequency, Brake End Point, Drive Frequency, Reverse, Motor Rotation, Battery Type Selection, Starting Line Mode, Motor Temperature, Voltage Cut-Off (via NovaLink) and Profile Selection | |
11-17-2009, 09:16 PM | #20 |
Ya, I saw that over at RCP. 3s, nice.
