11-15-2009, 07:02 PM | #1 |
RCC Addict Join Date: Jan 2009 Location: ?????
| lipo charging ?
i have some 1350mah 2s lipos and also a dynamite 2-3s lipo charger. and the settings on the charger only allow for charging of 500mah 1500mah and 3000mah. can i charge my 1350mah's on there without a problem? thanks for any help |
11-16-2009, 08:33 AM | #2 |
c'mon guys, i have a friend that really needs this info, and i dont have an answer. .. . |
11-16-2009, 09:07 AM | #3 |
Quarry Creeper Join Date: Jun 2009 Location: Who's asking?
You could charge them on the 500mA setting (.27C) or the 1500mA setting (1.1C). The settings are not in mAh but are the available charge rates e.g. .5amps/1.5amps/3.0amps. Is your friend using a balancer with this charger? If not I would use the 500mA setting and charge in a fire safe bag. Better yet I would get a better charger with a built in balancer. |
11-16-2009, 09:15 AM | #4 |
What is the battery in question? Depending on the battery, you should be able to charge it at 1.5A and most definitely charge it at 0.5A.
11-16-2009, 09:16 AM | #5 |
11-16-2009, 09:19 AM | #6 | |
11-17-2009, 03:37 AM | #7 |
I wanna be Dave Join Date: Sep 2009 Location: Nor Cal
Better not charge lipos incorrectly. Do a search and watch some nasty lipo videos an pics. Not a pretty site. YOU DO NOT WANT TO PLAY AROUND WITH LIPOS!!! Wait, did I just say that??:? Of course you want to play around with lipos!! Just charge them correctly and in a lipo sack or an Ammo box like I do |
11-17-2009, 07:44 AM | #8 |
Quarry Creeper Join Date: Jul 2009 Location: Derby
I have the Turnigy Lipo's the same size and I charge them at 1.3a. My charger has a built in balancer though.. From what the documentation on the battery max charge rate is 1P.. So a 1300mah would be charged and 1.3 amps.. max..
11-17-2009, 08:04 AM | #9 |
Rock Crawler Join Date: Nov 2005 Location: Rock-throwing country
| What is it's listed charge rate is it 1c, 2c or higher? Is it a newer turnigy? If it's a newer one it's probably rated at 2c charge rate which means it can be charge up to 2.7 amps (1350 x 2=2.7). If thats the case it will be perfectly fine charging at the 1500 setting. If it's rated 1c then the safe thing to do is charge it at the 500 setting. I said safe if it was me I'd still charge it at 1.5 (just do it in a lipo bag or outside on concrete) more then likely it will handle it.
11-17-2009, 08:17 AM | #10 |
Rock Stacker Join Date: Oct 2009 Location: YORK
does everyone chage their lipos in a fire bag? or is that only needed if you dont use a balancer?
11-17-2009, 08:24 AM | #11 | |
If I'm charging inside I'll set the battery inside a baking dish or on the concrete in the garage. Last edited by Mr Glassman; 11-17-2009 at 08:26 AM. | |
11-17-2009, 08:28 AM | #12 |
i just watched some videos on lipo explosions |
11-17-2009, 08:52 AM | #13 |
Rock Crawler Join Date: Apr 2008 Location: SO CAL
I have the dynamite vision peak ultra charger, i assume that is the one you are talking about I charge my 1900mah 2s Lipo at 1.00 and it has been working fine for about 1 year I use a comman sense lipo battery ballancer as well |
