11-17-2009, 04:28 PM | #1 |
| HH esc questions
do i need to run a bec with a hh esc, i'm running dual hh 7t pullers and a hitec 7955tg , my servo stalls out alot so i'm sure its because there is no bec because it never did this when i had fxr and bec
11-17-2009, 04:48 PM | #2 |
Has your servo gotten really hot? Can you describe the stalling, if the rest of the rig shuts down or if the steering just gets weak?
11-17-2009, 05:16 PM | #3 |
well i'll be drive and while i'm driving my lcc and i have my car in a small bind and i go to turn my wheel the steering will stop for about 3-5 seconds i don't remember if the car stopped to, i was more thinking about the steering, and no the servo wasn't hot, and i did notice when it did this the buzzing stopped then it turned back on once i regained steering, it did this mostly while i was driving so thats what led me to conclusion of having bec problems
11-17-2009, 05:34 PM | #4 |
Could be the BEC cutting out under higher loads, or your servo may have been previously overheated and it is pulling the big amps.
11-17-2009, 05:37 PM | #5 |
RCC Addict Join Date: Jun 2009 Location: California
John, have you had many reports of this problem with your TM? People not running BEC's? |
11-17-2009, 05:38 PM | #6 |
i don't think its the servo, i didn't do this last time i drove the car as a shafty, so do i need to get an external bec, or i'm not sure if it this esc, but i think it is, can i program the bec through the computer, and do you mean big amps from the battery or the esc, because that battery should have plenty of amps to move it and anything else
11-17-2009, 05:44 PM | #7 | |
11-17-2009, 05:45 PM | #8 |
11-17-2009, 05:46 PM | #9 |
No. He is saying if your servo was damaged or overheated at one time in its life, that it could be pulling to many amps, because its not working properly. Run a BEC and see if it fixes the problem, then you will have some sort of answer. Last edited by fa1rch1ld; 11-17-2009 at 05:49 PM. |
11-17-2009, 05:50 PM | #10 |
how hot is over heating for a servo its never been to hot to touch, but it has been on the high warm side before after some long runs but never hot,
11-17-2009, 05:52 PM | #11 |
11-17-2009, 06:07 PM | #12 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I'm running the same ESC with two 45 turns and a futaba 9157 on my berg. I can't get the system to brown out at all so far. I wouldn't think those motors would pull that much more juice but I could be wrong. |
11-17-2009, 06:12 PM | #13 |
| i've been watching threads for awhile now, i haven't seen anything about hh esc and servo problems, i search for hh esc bec i see nothing about it or am i missing something
11-17-2009, 06:32 PM | #14 |
i just got onto hitec and i found that on a load this servo pulls 4200 mah so put this into amps it pulls 4.2 amps (i think i did my math right) it has a 5a bec does 2 pullers pull .8 amps from the bec when you got a load on them http://www.hitecrcd.com/product_file...nal_080215.pdf |
11-17-2009, 09:54 PM | #15 | |
The amp rating from the factory doesn't help us much actually. It may be a rating to produce maximal torque. Unless the drive board has amp limiting, the servo motor will stall as much amperage as the battery and wires allow. I would say try a BEC. It may solve it. It could still be a amp hungry servo, however. Swapping in another servo would be a good way to see what's up too. The best solution would be an amp meter to see exactly what is happening. I have seen and killed a lot of hitec servos. They can cause a TON of weird problems when they go bad. Last edited by JohnRobHolmes; 11-17-2009 at 09:58 PM. | |
11-18-2009, 01:47 AM | #16 |
11-18-2009, 01:57 AM | #17 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
11-18-2009, 02:21 AM | #18 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
I'm running 2 10T pullers and a HT7955 and Punk dig on 3s with a HH Torque Master ESC. I've had it under some nice binds with zero issues! I would say it pushes the servo as hard as a Castle BEC! I would check your servo. Try what John said and swap another servo in and see if that is the prob.
11-18-2009, 10:13 AM | #19 |
Quarry Creeper Join Date: Jan 2008 Location: pittsburg
| yea it definitely sounds like your servo was overheated or over stressed at one point or another during its life. a damaged servo wont be fixed just by giving it proper voltage. if the motor of the servo has been damaged at one point or another, when it is put under load it will take the servo extra power to do basic things and it will over heat. a servo that over heats pretty much means its on its way out. this has nothing to do with the esc/bec. its the servo. i have the HH esc on my berg with integy handwound 45's, dig switch, 3s
11-18-2009, 05:46 PM | #20 |
found my problem i had my voltage cut off turned off and i'm running a123 cells and i was down too like 3-4 volts so once i charged the battery it stopped stalling in a bind since there wasn't enough torque to overcome it, i feel stupid right now, buyt problem fixed, i think i'm gong to upgrade to the 7950, is there a way to put the 7.2 volts to the servo with the built in bec
