11-19-2009, 08:56 PM | #1 |
Newbie Join Date: Nov 2009 Location: The Arctic
| Having issues.
My buddy asked me to take a look at his racer. I got the battery all charged up and turned it on. It just jumps around and the tires twitch but that's it. Everything appears to be hooked up right. The control does nothing at all which made me think it could be the reciever. I picked it up and the tires started spinning full throttle. Now I think it could be the ESC (tazer 15T) Any ideas from someone who knows more than I do?
11-19-2009, 09:19 PM | #2 |
I wanna be Dave Join Date: Jan 2006 Location: ...the burning end of the rope.
it could be a few different things,,,when you picked it up was the throttle pulled on the Tx? how long since the motor was cleaned or serviced? do you have another motor you can wire in? |
11-19-2009, 09:23 PM | #3 |
No spare motors, i cleaned it out tonight and the controller wasn't even on.
11-19-2009, 09:26 PM | #4 |
Rock Crawler Join Date: Oct 2009 Location: Greenville South Carolina
If it's hobby grade you might need a bec.
11-19-2009, 09:29 PM | #5 |
Quarry Creeper Join Date: Apr 2006 Location: Pittsburgh
11-19-2009, 09:31 PM | #6 |
uh yeah,,the controller is just that,,was the radio off? is that what you meant? make sure there are good batteries in the radio and turn it on for any kind of checks on the rig with it on,,otherwise the Rx picks up random signals and the truck goes nuts |
11-19-2009, 09:32 PM | #7 |
11-19-2009, 09:32 PM | #8 |
11-19-2009, 09:33 PM | #9 |
11-19-2009, 09:37 PM | #10 |
The radio was on.
11-19-2009, 09:37 PM | #11 |
Ok, I've recovered now. You always have to turn on the Radio (Tx) before the car. when the car is turned the receiver looks for a signal from the radio. The car will definitely be erratic /out of control if the radio isn't on first. |
11-19-2009, 09:39 PM | #12 |
do you know what kind of radio and receiver is in the car? 2.4 ghz? fm? am? does it have a telescoping antenna or a short hinged rubber one |
11-19-2009, 09:40 PM | #13 |
| The receiver may be to close to the ESC. Or you could be getting interference from contact with metal. e.g. metal chassis. Also watch your wire routing. Try to kee power away from signal wires. Meaning away from antenna/servo wires. That may help. |
11-19-2009, 09:41 PM | #14 |
None of my rc's ever do that, are you quite sure about that?
11-19-2009, 09:42 PM | #15 |
| Ok tried that now it just sits there. Does nothing at all.
11-19-2009, 09:42 PM | #16 |
yes hes sure,,,over time wires begin to wear out and lose their ability to transmit power and signal,,things change even if you dont see it
11-19-2009, 09:43 PM | #17 |
do you have a meter?
11-19-2009, 09:44 PM | #18 |
11-19-2009, 09:44 PM | #19 |
11-19-2009, 09:48 PM | #20 |
make sure the antenna wire coming out of the receiver is completly away from everything else in the car,,even take the reciever out and let it hang outside the car and try it...if you have a meter check to make sure the voltage coming out of the battery is close to its rated voltage,,if you have a bad cell in the pack it may charge ok but may not discharge right to make the car work you can also check voltage coming out of the esc to make sure its sending volatge to the motor,,if it is then put your meter lead across the motor tabs pos to pos and neg to neg and spin the wheels to see if you get any voltage out of the motor,,that will give you an idea if the motor is fried |
