11-22-2009, 11:19 AM | #1 |
Newbie Join Date: Jun 2009 Location: southern tier, east of corning
| Nomadio React voltage readout issue
Hi folks, I hope someone here can help me out as Nomadio seems to have jumped the ship on support for their product, and pulled the plug on their support forum website that I would normally be looking there for the answer to my issue. I am trying to use the separate voltage inputs on my transceiver so that I can set an alarm for lipo pack minimum voltage so I don't burn any packs up. I connected a servo wire set to my battery and plug it into the transceiver and it reads 22.7 volts or thereabouts, double what it should read and doesn't drop with usage. Is there a fix, adjustment, or something in the setup that I am missing to use 3 cell lipos with my rig and have the system be able to monitor the actual packs voltage accurately?? I don't like relying upon the Losi cutoff led on my speed control, nor its drop (huh, ur crawling and hardly moving most of the time) in performance to alert you of dangerous conditions for your batteries.. Thanks in advance, Chuck |
11-22-2009, 08:04 PM | #2 |
Quarry Creeper Join Date: Feb 2009 Location: Gold Bar
Had the same problem with mine. Bought new from A-main hobbies. Nomadio said send it in and they would fix or replace the transciever. Never did get around to sending it in and well now I cant.... Radio reads just fine with another transceiver. |
