11-24-2009, 01:21 AM | #1 |
Rock Stacker Join Date: Apr 2006 Location: Clovis
| ESC fan questions
Maybe this is a stupid question, but I searched and couldn't find an answer. I'm looking to put a fan on my Mamba Max. It seems to be getting too hot, I haven't checked the exact temp but I can't comfortably keep my hand on it after a bit of running around. So the fan I'm looking at is a Yeah Racing Tornado cooling fan. It seems like it will be a great fit for me, moving plenty of air and it will fit the ESC. The problem is that the info says it is 8.4v max. I plan on running a 3s lipo before too long. I thought about a BEC but I will be using it for the servo and have it set between 6.5-7.4v. What I'd like to know is has anyone run one of these, if so, have you upped the voltage without any issues? Does anyone have any other suggestions? |
11-24-2009, 01:24 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Plug your fan into the RX. The Novak fan works great to. But if your ESC is getting that hot it's because of your gearing or your over powering your motor. What motor and pinion/spur are you running? What battery?
11-24-2009, 01:29 AM | #3 |
11-24-2009, 01:33 AM | #4 |
What rig is this in? Your ESC shouldn't be getting hot at all?:?
11-24-2009, 01:44 AM | #5 |
I wanna be Dave Join Date: Sep 2005 Location: *
Is your ESC set to Brushless mode???
11-24-2009, 01:44 AM | #6 |
An AX10, stock chassis, wheels, tires, axles- it started out as a RTR, although there is no proof that it ever was. The motor seems to get a little warm as well. I'd have to double check, but I'm 99% sure it is, only doubting now that you ask. Last edited by rock_krawler; 11-24-2009 at 01:48 AM. Reason: added quote/answer |
11-24-2009, 01:46 AM | #7 |
11-24-2009, 01:48 AM | #8 |
11-24-2009, 01:52 AM | #9 |
I'll double check the mesh once it's all put back together. I did set it with the old piece of paper between the gears trick.
11-24-2009, 01:53 AM | #10 |
11-24-2009, 01:57 AM | #11 | |
With what you have told us your ESC should be fine. How long do you have to run the rig before you would say the ESC get's to hot to hold your finger on for 3-4 seconds? | |
11-24-2009, 02:07 AM | #12 | |
I think I'll check the axles then while I have it partially torn down. It couldn't hurt to give them a freshening up. It may be a few days but I will report back with my findings. Thanks for the help. | |
11-24-2009, 09:01 AM | #13 |
Quarry Creeper Join Date: Dec 2008 Location: B.C. Canada
I got a 12v small fan from Ebay. screwed it into the heat sink. Search "mamba max fan" on there, the seller has all different kinds of voltages.
