11-25-2009, 07:21 PM | #1 |
Quarry Creeper Join Date: Sep 2009 Location: Abbotsford BC
| What Servos?
Hi guys, I was hoping I could get all you hardcore comp guys on this one, What servos do you like to use, in regards to longevity, torque, and price? Thanks in advance! |
11-25-2009, 08:01 PM | #2 |
I don't have one but a hitec 7950 is my personal fav over 400 oz of torque and for a resonable price of about 120, i have the 7955 and its works great too
11-25-2009, 08:50 PM | #3 |
I wanna be Dave Join Date: Nov 2008 Location: Where freedom is earned.
11-26-2009, 10:51 PM | #4 |
I'm also not so clear on the topic of bec's Is the purpose of using a bec to allow your servo to run at higher voltage to get more torque out of your servo? |
11-27-2009, 05:08 AM | #5 |
RCC Addict Join Date: Aug 2008 Location: Charlotte, NC
11-27-2009, 05:14 AM | #6 |
Rock Stacker Join Date: Oct 2009 Location: Camp Hill
A bec does two things...The priamry reason is to supply an adequate amount of current to supply high power servos. As the amount of work a servo is asked to perform increases, the draw or amount of current increases. If the supply is not adequate for the demand, the voltage drops. As the supply and the voltage drop, the amount of work the servo can do falls as well. The BEC is desiged to bypass the limited current supplied by the BEC circuit in the speed control and supply a much higher amount of current drawn directly from the battery. The second function of the BEC comes from the fact that most batteries supply a higher voltage than the servo can handle. The BEC steps the voltage down from 7.4 or 11.2 volts down to 5-6 volts, the amount that most servos run at. Some of the BEC's allow you to adjust the voltage to supply the maximum amount of usable voltage the servo can handle in order to maximaze the amount of torque the servo makes. The key is to know how much voltage the servo can handle without going up in smoke (another topic for another thread). By using the maximum voltage with a larger reserve capacity (higher amperage supplied by the BEC) the servo will make the most power that it can supply while isolating it from the ESC and the reciever.
11-27-2009, 06:28 AM | #7 | |
Pebble Pounder Join Date: Oct 2009 Location: Whitmore Lake
11-27-2009, 06:44 AM | #8 |
Quarry Creeper Join Date: Jun 2009 Location: Fredericksburg
11-27-2009, 12:28 PM | #9 |
sweet thanks for the BEC info! What BEC's would you recommend? Castle Creations is the name I keep hearing.
11-27-2009, 01:00 PM | #10 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
CC BEC all the way. I run a Jr9100t servo. its 370oz @ 6v, i run it @ 6.2. I liked that JR has a 3 year warranty, and it was on the shelf when i wanted it. its weird too, when i got mine it was $114.99, and the 8711 was $139.99. now the 8711 is hard to find, and i see mine listed @ 139.99? Last edited by BEELZEBOB; 11-27-2009 at 01:03 PM. |
11-27-2009, 01:02 PM | #11 |
I have the Castle Creations..the smaller 10 amp one and I have the positive and negative wires soldered directly into my steering servo. I took the red and black wires out of the plug for the servo and the white signal wire is the only wire left in the plug going into the reciever. The orange wire (signal wire) on the bec is covered in black tape and the red and black wires from the bec are soldered and heat shrinked right onto the steering servo wires. This way, I still let the power from the speed control come in and power the receiver and the dig switch servo (it's a tiny helicopter servo that takes no power) and all of the current from the bec goes toward steering.
11-27-2009, 05:14 PM | #12 |
sweet thanks for all the help guys... I think it's time for a revision to my trucks electronics... As it sits now it has a hitec SRX radio which is broken and not sending a good signal, a 645 MG servo, and a 6 cell split pack... I'm thinkin I'm gonna go LiPo, DX3R, HS-7950TH and a CC BEC any other recommendations? |
