Thread: sidewinder esc programing?
Old 12-09-2009, 06:13 AM   #1
Default sidewinder esc programing?
My lcc has been down for a couple weeks due to waiting for parts... When i got it put back together last night i had to do the manual re-programing with my remote and when it was finished i got full throttle fornt but on creeping slow reverse? I tried to do it a bunch more times and got the same results... Can somebody explain to me what i might be doing wrong? Thanks in advance!!
SRP customs is offline   Reply With Quote
Old 12-09-2009, 06:28 AM   #2
Sounds like you may have used a limited reverse setting, the default is 50%. Save yourself some time and use a Castle Link. Your LHS may even have one they will let you use in store.
Did you recalibrate your radio to the ESC as well?
shaggybob is offline   Reply With Quote
Old 12-09-2009, 06:50 AM   #3
x2, find someone with a castle link
What remote are you using? I'm thinking it's possible you changed the EPA of the brake
engineerjoe is offline   Reply With Quote
Old 12-09-2009, 08:40 PM   #4
I am using a tq3. I have had to reset it a couple times before and i did just the same and this time it is different... I guess i will just have to go to the hobby shop to see if they have a link....
Old 12-10-2009, 11:14 AM   #5
Yea get the link. I changed Radios and tried the manual calibration. Well had problems. Did it with the link up and running now.
The_REDRASCAL is offline   Reply With Quote
