12-09-2009, 05:51 PM | #1 |
| HH BR-XL ESC issue
I just received the HH BR-XL ESC. I don't have any reverse. I have hooked it up via Castle Link to verify the mode. It is set to Forward to Brake To Reverse. When I hold Reverse the light flashes fast pulses red. I changed the profile to Proportional w/ Reverse Lockout and it works fine double tapping. Switched it back to Forward to Brake to Reverse....same boat....nothing. I did hook up a voltmeter to the motor output posts and there in no voltage coming out while reversing in that mode. Has anyone had this happen? I have posted this in John's Q&A thread but no reply yet. |
12-09-2009, 07:17 PM | #2 |
Rock Crawler Join Date: Dec 2005 Location: East Texas
I had a sidewinder that did this to me awhile back and turned out it was being really picky on my throttle trim. I reprogrammed over and over and eventually adjusted my throttle trim just a bit, then it found neutral and worked flawlessly for months. Hope this helps
12-09-2009, 07:26 PM | #3 | |
12-10-2009, 07:03 AM | #4 |
John is aware of my issue now and is looking into it.
12-10-2009, 07:08 AM | #5 |
Yep, a firmware bug looks to have come up. Be sure you have 1.02 firmware, but it looks like the last run has the glitch even with 1.02.
12-10-2009, 09:58 AM | #6 |
easy fix, just reload 1.02 firmware. The one put on there is an incorrect 1.02.
12-10-2009, 10:37 AM | #7 |
12-10-2009, 10:40 AM | #8 |
Now I just have 100 more people to contact about the issue...
12-10-2009, 10:45 AM | #9 |
Rock Crawler Join Date: Feb 2005 Location: Oxford, MA
Only 99 more. I'll reload the firmware!
12-10-2009, 10:56 AM | #10 |
I wanna be Dave Join Date: Sep 2008 Location: behind the wheel of a monster truck...
98... |
12-10-2009, 03:47 PM | #11 |
Everything is good to go now. Thanks JRH
