12-11-2009, 10:17 PM | #1 |
Quarry Creeper Join Date: Nov 2009 Location: Sunny cali
| Novak 55T break-in ??????
How do I properly break in a Novak 55T motor? I just got a Rooster/55T combo :-P. BTW,I have a Checkpoint with the motor break-in ability!! Thanks |
12-11-2009, 10:27 PM | #2 |
RCC Addict Join Date: Oct 2008 Location: Plainfield, IL.
Ive never heard of breaking in a electric motor...
12-11-2009, 10:36 PM | #3 |
12-11-2009, 10:42 PM | #4 |
I wanna be Dave Join Date: Sep 2008 Location: four o six
Ive heard the new way is break it in a glass of water for about 15 min...or till the brushes contoured to the comm.... I use to run it with a 6cell till the battery died... |
12-11-2009, 10:59 PM | #5 |
12-11-2009, 11:07 PM | #6 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Water break in is actually an old school method that still works well and has become popular again with guys running Slashes and Traxxas Titan 12T motors. It reduces friction between the brushes and commutator during the proccess. If you break it in with water, just be sure to clean it with a good motor spray when you're done, and relube the bearings or bushings on each end of the can. Trinity Royal Oil works well. However, since you have a Checkpoint 1030, I'd suggest picking up some Comm drops and have at it. Either setting (1 step or 4 step) will work, and you can program the voltage as well. I believe I read somewhere that between 3 and 5 volts is optimal. A comm stick is a great tool to have as well if you don't have access to a lathe. It's not a replacement for a comm cut, but it will clean the residue from the commutator and prolong life a bit. |
12-11-2009, 11:14 PM | #7 |
Thanks Creepy! Thats all I need to know |
12-11-2009, 11:24 PM | #8 |
Sure thing I've been eyeballing one of those 1030's for a while now...killer charger. |
12-11-2009, 11:32 PM | #9 |
well, there you go... the water breaking is new to me...was out of the RC hobby for quite a while..so its new to me. good info CC |
12-11-2009, 11:54 PM | #10 | |
Here's more info i found http://www.rcuniverse.com/forum/m_5628228/tm.htm | |
12-12-2009, 12:13 AM | #11 |
| Some good info there |
12-12-2009, 11:29 AM | #12 |
| DONE! Broke it in last night! I used 2 double A batt. and a glass of rubbing alcohol.It took about 1 hour and 15 min. |
