Thread: hh puller 7t questions
Old 12-12-2009, 05:05 PM   #1
Default hh puller 7t questions
I have 2 questions relating the hh 7t puller
1. how many amps do you need to run it efficently
2. is it ok to spray wd-40 in the motor
thank you
rider12693 is offline   Reply With Quote
Old 12-12-2009, 07:30 PM   #2
I would stay away from wd-40 in the motor. It will just collect dirt and dust in the motor. As for the amps i dont know.
bikeman is offline   Reply With Quote
Old 12-13-2009, 07:57 AM   #3
ok thanks but i need to know the least amount of amps to run the 7t
Old 12-13-2009, 08:22 AM   #4
Holmes gives some recommendations on his site:
http://holmeshobbies.com/product.php...&cat=17&page=1
JeremyH is offline   Reply With Quote
Old 12-13-2009, 08:25 AM   #5
thank you but will be ok with 33 amps
Old 12-13-2009, 09:09 AM   #6
Right from the site:
Recommended lipo battery- 40 amps continuous for 11.1v, 30 amps continuous for 7.4v. Slightly longer than a standard 540 motor. Uses standard 1/8" pinions, and 25mm motor mount spacing- bolts up like a normal 540 motor.
madmax22 is offline   Reply With Quote
Old 12-13-2009, 09:20 AM   #7
yea i know i read it but that is the recommended amount of amps, i need to know if 33 amps is ok
Old 12-13-2009, 10:06 AM   #8
Suck it up!
Duuuuuuuude's Avatar
As long as you never get it bound up or put a heavy load on it you'll be ok. Be careful though...
Duuuuuuuude is offline   Reply With Quote
