12-17-2009, 08:22 PM | #1 |
Rock Crawler Join Date: Dec 2008 Location: Appleton, Wi
| Home brew winch controller...
I posted this in my 1.9 build thread but thought it might be useful for others to know. I bought a 3 racing winch and realized when I got it that it didnt come with a control unit. I sat and thought about it for a while and looked at the ones online and thought that the motor in the winch cant be much different from the motors in servos. So I tore down a micro servo from my old MLST and realized the motors are almost the exact same size. I removed the board and wiring, replaced the bulky potentiometer with a small pot switch from an old Hitech agressor I had. Next I soldered a female servo adapter and the small capacitor off the servo motor onto the servo motor wires. I adjusted the pot switch untill the winch steadied and didnt spool in or out. I ca glued the pot switch and shrink tubed it all together and sealed it up. I tested it all once done and it works perfect too! |
12-17-2009, 11:19 PM | #2 |
Rock Crawler Join Date: Sep 2009 Location: Abbotsford BC
another way to do it is remove the pot and solder a 2.2k ohm resistor from each outside pin to the middle pin, that aparently will keep the motor from turning.
12-18-2009, 07:03 AM | #3 |
Good to know. I wasnt sure what size resistor it would be. I tried some small ones I had. Im not even sure what ohm they were. But they didnt work. So I just put the pot in. Ill have to go and pick some of those up. Thanks for the info.
12-18-2009, 10:00 AM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Stuck in Missouri for now.
nice deal. I hate how big the controller is for the 3Racing winch in the first place, and this will allow you to use both an BEC and a "Y" cable to get the good power to it. Nice, now, when I get home, its time to do the same thing on mine so I don't have to cram so much stuff into a waterproof box.
12-18-2009, 10:23 AM | #5 |
Quarry Creeper Join Date: Dec 2008 Location: Post Falls, ID
| you can always just play with the trim on your radio anyway. just make sure the glue is solid and you should be fine. i did the same thing when i ordered a winch without a controller. makes ya glad you hold on to those dead servos huh.
12-21-2009, 01:27 PM | #6 |
Rock Crawler Join Date: Nov 2009 Location: OKC, ok
12-21-2009, 01:57 PM | #7 |
RCC Addict Join Date: Apr 2009 Location: United States of the Offended
| These are the ones I used for mine: http://www.radioshack.com/product/in...ductId=2062325 |
